Oz07 Posted June 26, 2019 Posted June 26, 2019 Could someone please quantify in laymans terms the real world difference of a wall u value between .18 and .2 for me? Single storey dwelling with around 90m2 of walls exc apertures. It's the difference of 25mm on chosen wall make up and I think the gain of 25mm would be better.
Mr Punter Posted June 26, 2019 Posted June 26, 2019 It works out as 1.8 watts for each degree of temperature difference, so assume the average difference is 10 degrees, your poorer U value would lose 18 watts. Over a year that would be 158kWh, which will probably cost between £8 and £20 depending on fuel type.
A_L Posted June 26, 2019 Posted June 26, 2019 @Oz07 as http://forum.buildhub.org.uk/topic/10204-would-you-notice-much-difference-020-versus-017-u-value/?tab=comments#comment-172917 so about 1.2kWh/m2 per year
