ToughButterCup Posted June 13, 2019 Posted June 13, 2019 My distribution box for the MVHR ( sometimes called spigot box or manifold) will sit beneath a flat roof , but above a ceiling. The roof build up from top down is; Alvitra Avalon over 270mm of insulation on some super expensive vapour stuff - forgotten the name - the price was so traumatic 22mm OSB3 POSIs above the ceiling build up which is Vapour control layer 25mm insulation 12 mm plasterboard 2mm plaster skim. There's enough space for spigot boxes to sit comfortably under the POSIs. That means they are outside the heated envelope. (just) The supplier says not to worry : but they would wouldn't they? Everyone has that problem, said the rep, What do you think?
willbish Posted June 13, 2019 Posted June 13, 2019 I think, do you need the 25mm insulation? Is it going to be make a significant different to target Uvalue. The supplier is probably right, the temperature in the void between the posi's will be very close to room temp. Chance of condensation very minimal I would have thought.
