Yes that’s right ,we moved in after 1 year another 9 months before being signed off. Still some bits to finish.
Doing the self build bit on your own takes time.The good thing about getting the build weathertight quickly all the timber stays dry you get no cracks on all the joints on the walls and ceiling.
It is a good idea to fit one there , as then covers you when you fit other appliances that need a check valve.ie water softener,outside tap and other appliances.
Buy a 32 MPDE to 28mm copper fitting and a 28mm stop cock or lever valve .You can then tee off with a reducer tee for a drain down valve. You can also use a reducer tee for 25MPDE to a 22mm copper fitting. You could then reduce the 28mm copper tail to 22mm or 15mm for the supplies that need them. If I was doing this I would use end-feed copper fittings, but you could also use push-fit. You need to remove the sink base back and clip all plumbing back to wall. You can always fit a removable back with access later if required.
I agree with Kelvin .Every joint is a possible leak in the future . Why do plumbers still use copper and fittings for these situations? If the plumber had used Pegler MLCP or Rehau all that could have been done with minimal joints and in half the time.
If it’s worktop you are cutting and the edge is on show ,cut it 10mm approx from line with jigsaw then finish with router and clamped straight edge.You then have an edge you can laminate .
I have used Pegler Tectite MLCP pipe for all my H+C pipe work . I found it an excellent product bends like copper comes in 50mtr coils,no joins under the screed . You need to use there pushfit fittings and inserts also a couple of special tools to prepare the pipe.
We had an Escrow bank account arranged by the kit builder when we paid for our German build to the UK .
Staged payments all worked well. Need to be FCA approved company here,
We have a German Build they used Würth Eurosol 60mm wide.The tape is brilliant but expensive.
The air tightness test was .83 so obviously does the job .
