readiescards last won the day on August 21 2017
readiescards had the most liked content!
Personal Information
Location
Lincolnshire, UK
readiescards's Achievements
Regular Member (4/5)
118
Beware this is very tedious Each window has 9 or more lubrication points, some hard to get too to be done every 6 months the manual says. I love the look of our internorm windows and the triple glazing is amazing for thermal and noise insulation but the whole point of the alu-glad solution was for low maintenance, so it is mega annoying the additional maintenance need to lubricate them so often and in so many places. Surely there is a better solution?
Ha ha. Well how many people do you know that have a temp sensor in their airing cupboard that they check on to see if the immersion tank is full of heat? I know one. Me! So yes I find the new Sunamp LEDs very useful/interesting. Whether my holiday cottage guests will be quite as interested as I am is another matter?!!
The 3 year old PCM58 failed in our farm's holiday cottage, spitting out its salt, a couple of weeks back. Called up Sunamp Ltd and within 10 days had a new one delivered, installed and working Steven McElhinney fully understood the need and actioned a response, working within my time frame so hot water ready for the next holiday cottage guests Very pleased.
Spray foam under room in roof floorboards - expensive option?
readiescards replied to readiescards's topic in Heat Insulation
200mm between roof trusses - can easily feel draft movement 100mm between floor joists between cold garage and heated office - feet get cold in office -
I commission the unit and balanced it across the house but as the house is not that air tight the outside wind speed seems to impact the performance. I generally remove and wash the filters every 6-9 months, replace every 2 years. The heat transfer unit I wash maybe every 18 months (though never really get anything out of it). Because I find the running noise quiet annoying, at night I've set the unit to run very minimally (and we open the bedroom windows) so the vortices might be small at night. In my opinion there is a fair amount of cross flow leakage within the unit itself, almost as if the summer bypass unit works by relying on this cross flow leakage path. The manual says the fans should be cleaned as if it is expected they will get dirty. >what’s your pre-filter rating? Sorry I don't know.
5 years on, my thoughts are that spray foam insulation is expensive and fairly ineffective as an insulation product (maybe a side effect of it's breathability) I would not encourage anyone to use it. -
Just wondering since I last asked ( ) if anyone has found a neat way to clean the MVHR fan blades. Mine get a thin film of dust on them, which the manual says should be removed and I hope it will quieten it a little too. Paintbrush/toothbrush and hoover is my current method. Someone in the forum suggested a can of compressed air - anyone doing that/does it work? Many thanks Paul
Brickwork damp patch after prolonged heavy rain
readiescards replied to readiescards's topic in General Construction Issues
Thanks @mjsx it is still ongoing and indeed is the source of waking up in the night 'thinking WTF did I use that builder'? We have had the chimneys rebuilt by another builder after lots of investigations and expensive reports, this seems to have made the situation better - with only minimal drips in the recent November storms. (It certainly has improved the log burner having removed the damp vermiculite). -
IVT Ecolane ASHP - any owners out there?
readiescards replied to readiescards's topic in Air Source Heat Pumps (ASHP)
Apart from physically cleaning the outside of the unit and checking for obvious muck on the fan blades is there any other servicing needed of this (or any other) ASHP? -
Ventilation Boost switches
readiescards replied to Stones's topic in Mechanical Ventilation with Heat Recovery (MVHR)
That's interest. Very very rarely does the built in sensor kickin. My utility/clothes drying room is a long way from the Sentinel Kinetic MVHR, so I ran double pipe work, but often it feels 'steamy' to me but the boost does not kick in. For the wet rooms, have to manual kick the boost in, using a (long) momentary push of the boost switch (I have the unit in control mode 2 with the link install - I think) -
Just to say about from a relay issue, the two Sunamps in our holiday cottage (with UFH & Triple Glazing) have worked fine and no complaints of a lack of hot water (from up to 6 guests). so still 'marry'
