MikeGrahamT21
    2
MikeGrahamT21 last won the day on October 5
MikeGrahamT21 had the most liked content!
1 Follower
Personal Information
  • Location
    Yorkshire
9064 profile views
MikeGrahamT21's Achievements
Advanced Member
Advanced Member (5/5)
630
  1. Check the area of the event, it could be very local. Not sure if octopus prices are nationwide for agile or whether they too are local. The VPP is designed to alleviate local grid stress rather than national
  2. Yes they should definitely know what you are talking about. This is an updated Best Practice Guide which I followed when i did mine: https://www.inca-ltd.org.uk/wp-content/uploads/2024/04/INCA-EWI-Best-Practice-Guide-RENDER-V1B-01-10-24.pdf Gives all the detailed drawings showing relevant detailing for just about every situation you're likely to come up against during EWI installation.
  3. I’ll take some in progress photos when I make the next ones
  4. I was super impressed how much visibility I get, honestly wasn’t expecting so much. The window in this case is inset due to the EWI, and I’ve also brought it away from that by around 4cm, so maybe 24cm between the fabric and the glass as it’s shown there
  5. Yeah i thought about white, but thought it may be a bit too 'in your face' to look at from the street side, so I stuck with a grey similar to my window frames. I've got plenty of thermal images of my windows from the various heat waves this year, so will try and collect some next year (if we have any, probably won't now i've made these!) and upload them to compare. I don't currently have any ceiling fans, only portable ones which I can move about, but the noise tends to keep me awake. I do have an evaporative cooler which i get out when its rediculous hot, which when filled with ice packs knocks about 1C per hour off the bedroom temperature with the door closed, with the downside of adding a lot of humidity, but again, i don't have it on all night, usually set a timer for 1hr when i climb in bed, and a good 75% of the time i don't hear it switch off, but the ice packs only last an hour when its really hot
  6. I did the plinth insulation as part of the whole EWI system, using XPS.
  7. I decided I had to do something to combat the eventual indoor overheating which didn't involve installing air conditioning, this may be needed at some point if temperatures keep rising but i'd rather keep it as a last resort. I've been using all of the usual tricks in the book, opening everything up when its cooler outside than in, and shutting everything up during the day, which worked as well as it could, the bungalow is pretty well insulated so this strategy worked in the most part, but the prolonged heatwaves we had and tropical nights made it an impossible job to shift the heat. Keeping the internal blinds and curtains shut also helped, but the triple glazed units eventually heat up and then retain that heat for some time. Internally the frames/panes hit around 40C, which all adds to that air temperature over time. I have 6 south facing roof windows, and many years ago decided to get the external awning blinds which made a huge difference to the internal temperature of the windows on a hot day. The 2G ones used to hit well over 70C midday, but with the external blinds that came down to 50C, still hot but a big difference. The newer 3G ones, i currently have one with and one without an external blind, just bought one at the time to see how much difference it made on the newer version of the windows, as you'd expect this is much less of a difference as they are just better overall. Without the external blind the frame/pane hit 55C and with the blind, 47C. This was during the prolonged June heatwave when air temperatures were also very high. I looked into getting some external blinds made for the other windows to bring those internal temperatures down in extreme heat, and maybe just maybe give myself a better nights sleep when it happens, but was shocked at the cost. When I read of the impending El Nino and that chances of more heat next year, I decided that i'd get some external blind material, and make my own. Cue the sewing machine, not something i'm overly familiar with, so with plenty of practice, and all the right bits (as they're for use outside, needed UV stabilised polyester thread, a special needle as its thicker fabric and a special foot for the sewing machine due to the 'stickiness' of the fabric, combined with polyester webbing to strengthen the hems, and finally stainless steel fixings to stop rust), i made some very slow progress but have finally completed my first blind, decided to do the bedroom one first on the back of the bungalow, so its not particularly seen from the street side whilst i get better at the whole process, but on the whole i'm pretty pleased with the outcome. And from the inside the outlook is like this. Very dimmed light inside, but a good view out. Obviously time will tell as to how effective it will be, but im confident it will have a good impact. The two windows on back of bungalow are surrounded by 100mm thick EPS External Wall Insulation, which provided its own unique challenge for fixing. I found these Fischer fixings which I hadn't come across before, and have to say I'm really impressed with them, though they are rather expensive. https://www.fischer.co.uk/en-gb/products/fixation-on-etics-insulation/fixing-in-substrate/thermax-8-and-10/stand-off-installation-thermax-8 So first one down, and concept works, just another 4 to make and fit before next year! Total cost including the Fischer fixings for all the material etc was no more than £300 for all 5 windows. Fabric came from this online shop, in bronze: https://www.fabricuk.com/fabrics/2298-sun-shade-mesh-wide-width.html
  8. Absolutely stunning, house too!
  9. Yeah I signed up for this and linked my inverter but so far I’ve had to do everything manually despite them saying it’s supported, I’ve emailed them but so far not heard back. seems odd that you can literally do nothing and earn £120 a year!?
  10. Whether right or wrong, I’ve had 4 extensions done on my bungalow and none of them have mortar below the DPC, only above, and haven’t had any problems in the last near on 20 years. I have read people mortaring under the DPC but not sure what it brings really, plastic is never going to adhere to mortar, not strongly anyway, and the weight of what’s above will keep it where it should be
  11. No better people the ask than the worktop template people, they’ll have come across is many times I’m sure. I couldn’t recommend anything as I don’t have an island unit
  12. As above, what council are you under…they should be a department and more than a single person, although you have a named contact, others there should also be able to come out and advise. May also be worth copying in the entire department email address along with your named contact, could help move things along… and the other thing, they could just be on annual leave
  13. Was watching an episode of the great house giveaway only the other day from series 1 and that had a property on it with a single skin extension and the chap said it needed another skin to be mortgageable
  14. Definitely much much better than 2G, and they also do one with thicker glass on the outer pane which lessens it even more, designed primarily for use in bedrooms, so may be worth looking at that unit
  15. Definitely not ivy. If its a shady wall, you could look at Hydrangea Petolaris which is a climber
