Seeoda
Personal Information
  • Location
    IE
Seeoda's Achievements
Member
Member (3/5)
0
  1. I did this recently and I want to show the method to help others. I used Volume flow rate (m^3/s) = Speed (m/s) * Cross-sectional area (m^2) Very easy with ChatGPT
  2. That is really interesting. I take it that your house is airtight enough not to be impacted by high outside humidity like mine seems to be.
  3. It is already helping. Although last night it was very rainy and thus it ran on boast forcing me to turn off the whole system to get sleep.
  4. I found it was set at 60% RH. Changed it to 68%.
  5. This process is proving very painful haha. I will be telling people to stay as far away from Venta Axia as possible. Such shoddy design, quality and customer service.
  6. Hi all, I have been some very heavy summer rains here and I find it triggers the boost mode of my Vent Axia Sentinel. Normally my home would be about 50-55% relative humidity but on very wet days it might be 60%, but I don't consider 60% inside excessive at all. While the the noise of the boost is disturbing my sleep. Any suggestions? Thanks.
  7. Putting in rockwool or fibre into the void might not have a huge impact on soundproofing. What noise do you have? if you want to stop foot steps, use mass loaded vinyl.
  8. I am sure some enterprising person could correlate different objects like paper, or cloth to flow rates and make a nice bootstrap calibration method. Might not work if you have vents that screw outwards but otherwise would be good
  9. I bought the conical filters to insert into the extract valves. Unfortunately, my kitchen extract is so weak at the moment I cant fit the filter there yet (just 3.5 l/s), so I only have it on a bathroom valve. I dont know what sort of flow you need to have 13 l/s after fitting, my goal flow. They catch a huge amount of dust in the bathroom anyway.
  10. The MVHR wont help with temperature but it helps a load with humidity. But we'd be able to advise more if they explained if they had a blower test. I think that is the way to go.
  11. It can be where the state requires you to install an external hood. I am in this position now and I feel like I am butchering my house. BTW what are you kitchen extract flow rates? 13 l/s?
  12. This question s a major issue that doesnt seem to be really being looked at properly. In some countries, all rental properties legally most have an externally vented hood. I dont know what the solution is.
  13. Hi, I have a scheme house, over three floors. It is a tall but narrow house with its own branch MVHR system. Living in it has made be realise I deeply appreciate MVHRV, but the problem I have is that on the ground floor in the kitchen, the flow is too weak. There are a lot of food smells. The tested values are often just 2 to 5 (l/s) on this floor. I'd love a filter on the extract, but that would lower the pressure more. The kitchen has one extract. No input. While the system tends the system tends to be too noisy on the upper floors. I have flat channel ducts on the ground floor and the middle floor and round ducts on the top floor. The unit is in the attic on a hanging mount. It is a Vent-Axia sentinel. I don't have the budget to gut the house and change everything, so there is only a limited scope. I was thinking of some kind of hybrid system. Possibly a manifold on the ground floor to enable a second kitchen extract and maybe a second one to living room. Possible re do the flat channels to have less bends and better flow. With another manifold on the top floor to ensure a lower flow to nnoise sensative areas. Can you use manifolds on branch systems? I may be able to squeeze a radial duct or two from the attic to some rooms. Is this plan viable?
  14. As you say, the two go together, but I get the impression when a room is at the lower temperature range Co2 is a much better measure of human presence.
