Levo
Everything posted by Levo
MVHR is Largely Bogus
Levo replied to DavidHughes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
@JohnMoStrictly speaking my motivation wasn't saving money, it was saving Gas for the environment. But I would never say no to money😁 -
While I agree that the MVHR will benefit more in an airtight house, my 1970s house (50 years old now) has definitely benefited: 1- Pollens filtered out: You just need to increase the intake rate so you have positive pressure inside. That means some air leaks but on the plus side you reduce the amount of pollens coming through gaps. 2- Nice clean air, reduced CO2 etc etc 3- Bonus energy saving. Perhaps not as much as it would have been in an airtight house but still a respectable 30%+ (1-11k/16K) saving. Filters are not that expensive. I have just ordered some G4 filters at €22 for 10 (€26.5 including shipping). That is ~£4.60 per 2xG4 filter change. -
It was for my son and his life quality has definitely improved, as long as he stays inside 😟. But you need to get a system that will take M5 filters as a minimum. I have the Brink Flair with F7. In the autumn/winter I go to 2x G4 and once the Hay fever seasons starts (in about a months time for my son; grass and silver birch), move to F7+G4. -
Heat pumps won’t work in old homes, warns Bosch
Levo replied to Temp's topic in Air Source Heat Pumps (ASHP)
Well, what can I say. 1- I'd like to be prepared. 😁 And why do we need, at least some of us, 300BHP cars? 2- Being an engineer, having some margin has never hurt. If you are spending £15K on a system, what is another grand or two to have that buffer. 3- Also, as I said, I don't quite believe the manufacturers figures. They are a bit like car's MPGs. Only valid on a downhill slope, on a cold day with the wind behind.... -
The problem with AirSource HP is that as it gets cold, the efficiency suffers, so you are not able to supply the quoted heat while at the same time your need is increasing. So the system needs to be sized to be able to deliver the required energy at -15C. Otherwise you are toast, well I mean frozen!. I am not sure how realistic the cold temp figures the manufacturers are quoting. I know one needs to take any claim with a pinch of salt but besides that, what if their figures are for somewhere with drier air (lower humidity). That would delay any ice forming on the fans/radiators, therefore improving efficiency. That wouldn't apply to your usual UK weather with near 100% humidity almost every night throughout the winter... As an example, I have friends with a new (less than 10 year) house. I live in a ~50 year old house (maybe 30% smaller than theirs). Assuming their house is much better insulated, I figure they should need less energy to heat their house and at worst, the same amount of heat as we do. In our house we only turn on some of the downstairs radiators, around 5KW max output, and we never have any issues with not being warm. If anything the rest of the lot complain I keep the TV room too warm. I changed all the radiators recently, so know their heat output. My friends on the other hand keep complaining they are never warm on a cold night. So, their system appears not to be able to supply 5 KW. Their outside unit is rated at 15KW!!! So to me, Air source HP is good for mildly cold days but you need some backup for the real cold days. Best solution as the others suggested, install couple of A2A units which will do a lot of the heating and at peak times, use the boiler to back them up. Problem solved for 2-3 grand and fully prepared for that cold day. -
Good point. I figured around £65 a year (20Watts continuous at 35p/KWHr) for electricity. Some of this will be offset by the central heating operating less so less electricity for the burner fan, the water pump etc. Say down to £42. Add two sets of G4 at £4 each set, so totals to £8 a year. That is 500 - 50 = £450. Still a good saving. -
It has been 2 years since I installed a Brink 300/325. My main reason was 1- Hay Fever, 2- cleaner air and finally try and reduce the gas bills to help saving the environment and reducing the cost to achieve the first two. I have checked the gas bills the other day and it seems we were averaging 16K KWHr annually before Brink and it is in the 11K KWHrs afterwards. That is a 5,000 KWHr a year reduction helping the environment and a £500 saving a year for my pocket. So the payback for my DIY install at £3600 will be ~7 years. Just wanted to share. -
I have some cunning plans on this too. The box has Modbus support. And there are plenty examples for designing controllers using Raspberry PI and the like on Youtube. Let's see what I achieve in 5 years ?
Haven't started installing yet but bought everything I need (the famous last words...) I got a meter of 160mm foam pipe. I will fit 25cm on each port. It will also serve to reduce vibration. This I will reduce to 150mm using the adapter below from BPC. Then it is 150mm PVC for the bendy bits. I bought a 50cm Lindab filter for extract and 100cm for the supply side. Chose the 125mm size as it has a better attenuation profile and being very short, small impact on the pressure calculations. For the long runs to outside I decided on the 220x90 PVC as it will be easier to hide underneath the loft insulation. For distribution, I bought the Ubbink boxes and 75mm pipes, plenums too. Valves are a mix: For the kitchen I got a Filtered Extract Terminal from Paul Heat Recovery. Quite dear but has a replaceable F3 filter which I am hoping will catch the grease. For the rest I bought a mix of Lindab Airy (for the living rooms), Zehnder Luna (bedrooms) and BPC metal for the studies and bathrooms.
Hi, I think we are saying the same thing. I didn't say the TV isn't valuable to someone, as it is definitely valuable to me because I have a large one. Just that it didn't bring back a fiscal value. -
I am about to install an MVHR. All kit ready, waiting for marginally warmer weather. The reasons for my installation are: 1- Pollen filter to help cut down on my son's Hay Fever. 2- Air quality. I suggest people invest in a CO2 monitor and check the levels in a couple of rooms. You would be amazed how quickly it goes to red without ventilation. Trickle vents would bring cold (bitter cold these days) air in and I hate the cold air flow. Example: TV room ~23m2. Begin at 400-500, two people watching TV, 2-3 hours later in red (1200+). CO2 PPM below 800 is deemed good, above 1200 it is bad and it is acceptable in between. Imagine a similar size or smaller bedroom with 2 people sleeping for 8 hours. 3- It will reduce the gas usage somewhat. I mention this not from cost perspective but environmental angle. Some may argue that the CO2 cost of manufacturing etc probably outweighs this. I live in a 1970s detached house. It does have some gaps here and there which I will need to plug but the important rooms are reasonably airtight, so I am hoping it will serve to increase the air quality and remove the need to open windows and causing cold drafts and therefore providing better comfort. Looking at this purely from cost perspective is wrong in my opinion. Anybody who does, I assume (as an example) has no TV in their house as one can argue a TV provides 0 £ value, and is therefore just cost...so impossible to justify. -
Thanks Joe. Got distracted with other stuff at the moment, will follow up on this later.
Unfortunately yes ☹️ but having said that I could have got a really good price for them, I might still try. It is one of these things, you look at the price and it seems high and one ignores them. Now that I am looking at the PVC prices, they are not exactly cheap either. On another note, they are real clunky at around 20cm diameter and being soft, need to be handled with kids gloves. At least feels that way. Obviously once you lay them, you can forget about them. "... brown ones are not UV stable..." They will go in the loft and also under rock wool. Not much exposure to UV.
" ... to be 300% sure. " ? I am thinking of digging some of the existing insulation to make grooves and than put a 200mm layer on top, whichever pipe I use. Still not sure if I should do the bendy bits out of the unit using the round 160mm pipes and than the long runs using the rectangular ducts. I think these will be a lot more compact and easier to cover. The pressure loss in these is very similar to 150mm round pipes. Wonder if anyone had any experience with these? Good or bad?
I've been checking the prices for pipes and how to convert 160mm to 150mm. There are some sites selling "ventilation pipes" at quite high prices but I came across the 160mm underground pipes sold at Toolstation. https://www.toolstation.com/plumbing/160mm-underground-drainage/c267 The elbows are 87.5 degrees but if you are using opposing bends, you can compensate for it and the radius seems a lot rounder than the regular PVC pipes. Has anyone given a thought to these? Any reason not to use them?
I went with the Brink 325 from the dealer at the end. I turned up at the shop and they were quite helpful and also gave me an extra discount off the bottom line for the order which includes Lindab attenuators and Ubbink ducting and Plenums in addition to the Brink Flair.
Hi Olf, I will be installing into my 1970s house and SAP numbers only matter if you need some new build certification, as far as I am concerned. For new builds, the PHI certification should count for something though. I have asked CPC for a quote and got an almost reasonable discount but if you are about to order and would like to buy the UK version, we can ask for a better discount.
I have done some more investigation on this: On the technical side, the Flair 300 and 325 on the physical side are the same, same part codes except for one item; the 300 has Wifi for app control in Dutch, whereas the UK/Interrnational version 325 has a touch display unit. If you want wifi, you will need to buy R Home for 250-300. I have also spoken to CVC, the official UK distributor. He wasn't aware of the new UK shop fronts selling the Dutch version and contacted Brink and the Brink's position is that they are grey imports and will not be covered by warranty. Probably they can't refuse currently and one would be OK until December but who knows what will happen in the New year, especially with a no deal Brexit? I will try and get the UK version from CVC if I can negotiate an acceptable price. If there are others interested, we may be able to gang up?!
? If the PHI table is correct, the Flair 300 also looks to be quieter than the Zehnder and the Flair 325.
Anybody? @Olf Did you manage to find any more info on this?
MVHR - Intake and exhaust ducts lenghts
Levo replied to NickK's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I have done some calcs on this and given the other drops (pressure) in the system, it appears acceptable to have a few meters of pipe on that side. The following is for my nominal flow of 132m3 and ~5m of pipe. I allowed for 4 bends (1-2 to form a U after leaving the unit upwards, 3 to turn horizontal on the floor and 4 to hit the cowling). Tony is right though, if the runs get longer you may need to go up a step on diameter. By comparison, a 15m 75mm double run with one bend along the way to a bathroom extracting 45m3/h will have around 40Pa drop. This is excluding the pressure drops in the pipe, mufflers, bends and the distribution box. P.S. These are all my own calculations. -
Ventilation Rates Issue
Levo replied to worldwidewebs's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I assume that figure is with very low back pressure, @100Pa the flow drops to 575 according to the BCP specs. That I believe is with G3 filters (ISO 45% Coarse (G3)). As a matter of curiosity, do you have paper filter on the inlet side, I believe this unit supports the M5 filter option (ISO ePM10 50% (M5))? A finer filter will further restrict the air flow capacity. How much is obviously anyone's guess... -
Is Zehnder worth it?
Levo replied to BartW's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I just noticed this and thought I would share it here: The PHI Test method specifically states (on page 1!): " Before the start of the testing the type and model of the built-in filters should be checked. On the outdoor air side a filter of efficiency ISO ePM1 50%, on the extract air side of efficiency ISO Coarse 60%is to be inserted." The SAP on the other hand makes no mention whatsoever of filters. Just "unit as supplied buy the manufacturer". Meaning the test are done with Coarse 60% filters on both sides. This would go a long way to explain the generally worse efficiency figures in the PHI database and as far as I am concerned, for me, they would be the more accurate figures. Also, note that the Zehnder Q350 specs call for 350m3/h @ 100Pa (with G4s) but PHI states the max flow as 270m3/h which I think is related to using ePM1 (high spec F7) filters and not the G3/4. -
The problem being in the supply, did you check the filters? The external inlet cowling and the internal filter? Clogging up will reduce flow rates, no? -
I am going through the same process and pain of deciding Titon vs Zehnder. The only comparable Ventaxia is the Advance SX. The key functions for me are Constant flow and support for Pollen filter. Finer filter means higher pressure and higher spec fans. On that front, Ventaxia only claims support for ePM2.5 whereas both Titon and Zehnder support ePM1 filtration. Obviously, none of the published figures are based on the finer filters. I had the Ventaxia in my short list but discarded it due to the size of their filter which is under 500cm2 whereas Titon and Zehnder has 800cm2 filters. The smaller the filter size, the higher pressure drop you will have = higher fan speed = more noise... So, basically you get what you pay for.
