Everything posted by Adsibob
I’d be interested to understand why it’s more comfortable.
Welcome to the United Kingdom.
Certainly, it’s more likely that hell will freeze over than me paying them any money. It’s quite possibly the most expensive residential gas boiler on the market, so I intend to get my money’s worth. Currently, it is the manufacturer that owes me: 1) cost of heating 300L of water with an immersion heater 2) damages for stress and inconvenience of coming home to a cold house; 3) time costs of dealing with this crap 4) interest on the above.
Indeed! And on calling them this morning they did speak to a technical guy who said it sounded like a manufacturing problem. My installer is abroad till 10th Jan, and I really don’t want to take any chances (with gas leaks or loss of heating/HW over the next couple of weeks.
I called Veissman and they think it might be a manufacturing fault so are going to send out an engineer on Monday under the 12 year warranty I paid for. Of course if it’s not a fault, I get charged £144! You may be right about local gas supply. If there is a sudden drop in temperature as we had, everyone will suddenly use more gas.
Sorry my mistake. I think I calculated heat loss PLUS requirements to heat the cylinder at about 15kw and decided to go with a 18kw boiler. My gas engineer /installer laughed at me, and insisted it wouldn’t be enough. I think he was wrong but he’s the so called professional, so I just accepted his view.
Yea, I discovered the usefulness of this for the very first time yesterday. Once we had got the boiler working again, it powered up to 90% modulation, the highest I’ve ever seen it modulate to. I guess with the water temperature from the mains being quite cold, the house having an average temp of 17.8C and the UWC being cold, it needed quite a bit of power to heat everything up. It’s a 1920s semi that has been extended at the back on all levels. The back is therefore built to modern standards, but the rest, although covered in some 45mm of EWI and very airtight with MVHR, is ultimately solid wall construction, no cavity. Maybe the heat loss is only 15kw, but I erred on the side of caution, got to 18kw then my heating engineer practically doubled it! No short cycling thank god. But we didn’t make the most of the boiler’s capabilities unfortunately. I trusted the installer too much and didn’t commission a proper design. Had I done that, we would have got the benefit of WComp and low temperature heating. Instead we are heating water to 65C and sending that to the UFH manifolds where it is mixed down to about 35C. Silly really, but I’ve learnt my lesson now!
Just quite annoying that we came home to a cold ish house and no hot water. Turns out the fault had developed almost 36hr prior to that and even though it’s very cold outside, the house is sufficiently well insulated that it took that long for us to notice. Anyone know what I need to sign up to the boiler’s alert system? Is connected to the WiFi so might as well get that alert functionality working.
I hope you are right. I will call Veissman in the morning
Funnily enough, this has solved the issue. But I’m still concerned given the fault is something to do with a gas valve. If the gas valve is faulty I rather not run the boiler! Hmmm… what now?
We have a Veissman Vitodens 200-W system boiler. Installed new 3 years ago, only used for 2.5 years. At 35kw massively oversized, so rarely modulates above 40% (this was not intentional, I mistakenly followed my heating engineer’s advice and went much bigger than the 19kw my heat loss calcs showed). It has been serviced each year and still under warranty. But not much use the week before Christmas. Do I get it repaired by whoever I can find and then sue Veissman?!? Ffs! Here are the error messages:
Teething issues with MVHR
Adsibob replied to Tom's topic in Mechanical Ventilation with Heat Recovery (MVHR)
You will need to drill through the floor to find a way. You really don’t want stagnant water anywhere near this system. -
Not sure. Can you run a drain pipe upwards? Seems odd to me. -
The boost switches have probably just been wired incorrectly. They should be retractive switches, but there are different types so maybe the wrong retractive switch was used, or the right one was used but incorrectly wired. Easy enough to fix. I would just ask them to come back and address boost issue first and then any other issues. If you want an objective reading on the sound, you can get a decibel meter from Amazon for about £12. -
This is your problem. It is normal in my experience at least for the system to be audible when boosted. But you should only boost it occasionally, after a very smelly session in the toilet, or a long steamy shower. Fix the boost issue first. -
Zanussi combi oven/microwave tripping fuse
Adsibob replied to Adsibob's topic in Electrics - Kitchen & Bathroom
Thanks @ProDave so is that sufficient to serve an oven that has a “total electricity loading” of 3000W? -
Here are two photos, one showing the whole CU and the other a close up. I’m concerned given the labelling that the sparky has wired it for a microwave and not for a combination oven: -
When I look them up, all I find is “for this error you need to call an engineer”, not very helpful. What’s the difference and how do I tell? it just trips when switched on - ie at the intermediate stage before actually selecting a mode. -
We have a Zanussi ZVENM7K1 combination microwave/grill/oven. It was installed 3 years ago and we’ve been using it as a microwave oven for the last 2.5 years since we moved in. The max rating for the microwave is 1000W, and we have often used it at that setting. Last night we used it in oven mode, perhaps for the first time ever (I’m not sure) and it tripped the fuse. Trying to turn it back on we get a fault FH24 and then FO17 before it trips the fuse again. Given the oven is rated at 3kw, if it is actually the case that we’ve never used it as an oven, is it possible the electrician who installed it only provided a fuse for a 1kw Microwave. I notice that both the nearby isolator switch and the fuse on the mains consumer unit are labelled “microwave” so maybe he thought it was just a microwave and not an oven as well. If it is an installation error, is it straightforward to upgrade the fuses in the CU and in the isolator switch, or is the limiting factor going to be the type of cable used between the CU and the oven (which I estimate is about 12m to 15m long)?
I need an extra couple of shelves for some non-standard sized units that we bought from DIY Kitchens. They are playing silly b*ggers over the price they want to charge for supplying three extra "custom" sized shelves. Obviously for a company with their resources they could make up the shelves easily, but silly is the mood of the day there at the moment. Can anyone recommend an alternative supplier that will be reasonable about posting us three shelves cut to size. They aren't that big and the colour doesn't need to match exactly.
My search for a new amplifier (my first in fact) has come down to: 1) Leak 230; or 2) Cambridge Audio CXA81 Mk2 I will be using it to play my Technics 1500C turntable and a CD Transport (not yet acquired but I like the look of the Leak CDT); and eventually a vintage tuner. I have acquired a pair of Linton Wharfdale 3XP stereo speakers for just £60; I know they aren’t high end but seemed like a good speaker to get started with. Reviews mention bass can be a bit lacking with those speakers, so I want to use a sub. I have a powered Tannoy which is about 15 years old from a 5.1 system I no longer use. I can either use that, or purchase a passive sub if that is better. My question is: The CXA81Mk2 has an dedicated subwoofer out, whereas the Leak does not. I understand that this means that to use a sub with the Leak 230, I will need to wire the sub to the Leak’s pre-outs. My question is: is that a disadvantage in any way against the CXA81Mk2 given my intended use?
