craig
    5
craig last won the day on January 5
craig had the most liked content!
5 Followers
About craig
  • Birthday 05/27/1977
Personal Information
  • About Me
    I'm a self employed window and door specialist and have 15+ years experience in the Passive House and Low energy windows and doors market, supplying across the UK. I also supply consultancy services and can help you in obtaining prices and take the stress away from you.
    Happy to help in anyway that I can, drop me a message if you have any questions.
  • Location
    Fife
9968 profile views
craig's Achievements
Advanced Member
Advanced Member (5/5)
464
  1. Thanks for the tag @lookseehear, it’s been a great week on site with a bunch of cracking lads. Always makes the day go easier.
  3. https://cug.sfs.com/content/files/cd-files/default.aspx?id=f9e49d95-68ca-4c4e-a3a4-02a38fb77005&utm
  4. Best way is airbag/pump bag to lift the door and ensure no unnecessary stress put on the hinges. if the door is glazed, ensure the glass is properly heel and toed and the door will be fine.
  5. Apologies, looks like it could be a SFS hinge https://cug.sfs.com/content/files/cd-files/default.aspx?id=3ce7ecff-ece8-45b2-8eaa-27c3565d2657
  6. Have a look at https://www.illbruck.com/en-gb/products-systems/product-finder/me315-total-protection-tape/
  7. Highly likely Era 3d hinge, here's the instructions. https://www.eraeverywhere.com/globalassets/era/era-downloads/challenger-3d-adjustment-instructions.pdf
  8. It depends where you are sourcing your products, alu spacers are still fairly common unfortunately. Regarding timber beating uPVC, a good quality uPVC frame with 4/5 chambers will beat a timber aluminium window on performance. They will have testing done on the system or at least they will be using the tested performance of the profile from the supplier. The program they use (excel, winpro etc) will perform the relevant calculation and supply the Uw, some won't even display it and just say AA Rated for example. From recollection, the lambda (λ) are pretty similar across the relevant timbers With oak being slightly higher.
  9. Of course, you are correct but I was talking specifically about glazing on the assumption of a good frame but never qualified that point.
  10. That's not really correct. Triple glazing isn't primarily about reducing outside noise, its main advantage is improved thermal performance. A typical modern double-glazed unit might have a Ug-value around 1.0–1.2 W/m²K, whereas a good triple-glazed unit can be around 0.5–0.7 W/m²K, so the heat loss through the glazing itself can be roughly 40–50% lower. That doesn't mean your heating bill drops by 40–50%, because windows are only one part of the building's overall heat loss. Interestingly, triple glazing isn't automatically better acoustically either. For noise reduction, the thickness and combination of the panes, cavity widths and especially acoustic laminated glass can be much more important. A properly specified acoustic double-glazed unit can outperform a standard triple-glazed unit. So there are perfectly valid arguments about whether the additional cost of triple glazing is worthwhile for a particular property, but saying the thermal difference is minimal and triple glazing is mainly for noise isn't really accurate.
  11. Double glazing at 1.2Ug, isn’t bad at all but expected Ug now for double glazed. I can only suggest getting a system that can handle the weight.
  12. Factory glued but also done on site when required, as sometimes you need to fix through the frame and glass needs to be supplied loose.
  13. What do I use when it's a cost thing? Aluplast Ideal 4000 (Double) Aluplast Idea 8000 (Triple) Alternatively I would look at Rehau, Gealan or Salamander.
  14. Very easy to replace, obviously not as easy as glass into the frame without glue but it's a security thing as well. Doesn't take much longer to remove the glue, clean and put new unit in with the glue. It's also an extra, not standard.
