Bonner
Bonner last won the day on July 19 2023
Bonner had the most liked content!
Personal Information
Location
Lincolnshire
3997 profile views
Bonner's Achievements
Regular Member (4/5)
298
Amazing how much wind energy we produce, until it drops. Presume our batteries are in others, insignificant on this scale
- 57 replies
- virtual power plant
- export tarriff
National Grid Installation. Is this work acceptable?
Bonner replied to jimseng's topic in Power Circuits
The ducting is there for physical protection, not to keep it dry. I would be more concerned about the gaps where the cable can be impacted by external force. It should be armoured cable so belt and braces but it’s poor installation. -
Couldn’t you join a twin wall flue to your chimney? Might not need a flue liner or chimney breast? Would need the advice of a HETA installer of course
You don’t put anything in and whatever is paid into your account can be withdrawn immediately. If you want you could sign on and take the £25 and opt out. Nothing to lose really
- 57 replies
- export tarriff
That’s an awful lot of effort, have you considered an exposed twin wall flue? I chose this over a chimney as I prefer the simplicity and preserve the room volume. Also much better airflow around the stove.
Normally agree however this can’t last. Axle are winning some bids at less than 30p/kWh and paying us £1. They have funding to prove the concept and get people on board. Eventually the rate they pay will fall in line with other companies variable export rates.
- 57 replies
- export tarriff
They pay for anything you export during the event. This will be battery discharge, any excess solar being generated and anything else, if you have a wind turbine for example. I guess they need to see what is going through your inverter to check you are not simply rerouting grid power from another supply. You can sign up here :- https://vpp.axle.energy/landing?ref=R-WHARJUFG
- 57 replies
- export tarriff
Depends on your battery as well. I have a 8kW inverter but only export around 4.5kW due to max battery discharge current (50A). Any solar generation is on top of that since it is not going in the battery.
- 57 replies
- export tarriff
Works perfectly for me with Fox ESS battery and inverter. I believe some other systems can be troublesome, some not supported at all. PM me if you would like a referral 😃
- 57 replies
- export tarriff
Always the case with stoves! Presumably you want to get this up and running before the heating season? The chimney shouldn’t be an issue as long as you have a suitable and properly installed liner. I would be inclined to cover the existing materials rather than cut them back. The regs do allow for combustibles less than 200mm from the flue as long as there is an air gap of 40mm.
@Gus Potter, apologies for the delayed reply, I have been out of the country this week. Initial searches have revealed a problem with the land title which may stop us proceeding. In any case I really appreciate your suggestions and, if we do go ahead I will be in touch.
Do a Google image search or Pinterest to find examples. I would be inclined to make the worktop 5-10mm overhang all round including overhanging the end panel. It is a different material/element, wouldn’t look right if it is flush.
VAT Reclaim journey
Bonner replied to Benpointer's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Don’t think I used more than three words but something like that. -
VAT Reclaim journey
It may be they just don’t like building materials as it could apply to everything. My claim was only slightly more specific ie. plastering materials, electrical components, timber, decorating supplies. Where it was a mixed purchase, I picked the biggest value materials. That was 3 years ago so things might have changed. -
The vendor got consent (with S106). It’s on a road with the other back land developments so precedent has been set. Presumably not full fill trenches otherwise doesn’t concrete cost eventually overtake piling? Maybe I am worrying too much about the trench depth.
