Brickie
About Brickie
  • Birthday 12/25/1866
Personal Information
  • About Me
    I lie about my age.
  • Location
    London
Brickie's Achievements
Regular Member
Regular Member (4/5)
296
  1. Aren’t you having an Aco channel drain along the front of the concrete at the entrance?
  2. One option would be to build with standard mortar but rake out during construction,then hit the pointing in one go at the end. The extra cost of the white cement would be dramatically reduced this way. You could even be using the build as samples for variations in mortar mixing. The pointing could then be tackled when the build is water tight with yourself as the labourer to ensure absolute consistency of colour.
  3. …& my suggestions at work to have engineering bricks to 150mm above g/l is ignored every time
  4. 600mm x 100mm x 65mm concrete lintols are stocked specifically for this scenario.
  5. More concerned about the damp proofing & skim downstairs tbh…
  6. When appointing a bricky,I would ask to see examples of previous work in your chosen bond. ive seen some horror shows from even experienced trowels. Maybe talk to your architect about making any piers between windows work Flemish bond sizes-2.5 bricks long (552mm) is the smallest you can do in perfect bond & then it jumps to 4 bricks (890mm).
  7. Gently being the keyword. 20mm inside to out exceeds ‘gently’ in my book.
  8. Only issue there is having to notch the insulation around them & then tape over once the tie is in place. Alternatively,you could just insulate the whole thing & fix full length abbey channels through the insulation.
  9. This product solves every problem you mentioned. Not cheap but probably the best solution,other than doing EPS beads. Just to add,you’ll need to impress upon the Brickies the need to actually bed these in,rather than poking them in afterwards.
  10. I would suggest doing a LOT of research into the Damp proofing industry in general before committing to anything. without knowing a single thing about your case,I will say that I’m 90% certain you do not have rising damp. EDIT-please have a look at Peter Ward’s videos on YT.
  11. I’m not so sure-a straight crack through 5-6 courses of blue staffs? What were the temperatures during the cavity fill? (Including overnight) Edit-just had a closer look at the photos-that first bed joint above the blues looks either frost damaged or they’ve used a s**load of Washing up liquid as a plasticiser.
  12. Ignore the lintol shown-typical installation is more like this. A cavity tray is usually installed around the perimeter at around 150mm above ground level,this is a pretty standard detail now.
  13. A cavity tray isn’t really installed as per the drawing-it would come out across the top of a PIR sheet & then down to the outer leaf. Some people chamfer that sheet below to ensure a fall away from the inner leaf,which isn’t great thermally but probably preferable to any moisture finding itself trapped on a minute rise in the DPC tray. All the more reason why I don’t believe PIR is a suitable insulation material for masonry builds.
  14. Is there a steel ridge beam?
  15. I’d suggest a 1:1:6 mix is about right for aerated. In summer months,I ideally like to wet the top of the course below before bedding out,to kill the initial suction grab much the same way as old school plasterers would.
