Dan1983
Everything posted by Dan1983
Yes wiring is all low voltage, it comes with pre made wiring loom and you can run 20 spots per feed Cabling was a bit tight on the corners but managed to space it all evenly https://www.saxbytrade.com/products/exterior/decking
Nick, kept the steels exposed as was the look we wanted Still need to find a company to sort the triangular cuts as local places saying job is too small Matt, yes they are limestone from forest stone https://www.foreststone.uk/product/blissford-tumbled-limestone-paving/
Finally got the remote control power supply installed yesterday 3 spare outlets now for lamp post and garage up lighters Spot lights in the sleepers turned out well
Not yet Gaz but we are going to do it Few bits to finish it off really -Need the decorative stone between slabs and sleepers -New socket/ control box wired in to control lights -Top soil and about 50 lavenders for planters plus some turf to blend lawn in (guessing I need to crack on with this now or leave it until spring)
All finished a while ago Pleased with it all, the flow point ultrascape does seem patchy in a few areas but had heavy rain a couple of hours after final section was complete so not sure if that was the cause
Done with the laying now, grout next week One final cut to make down the side by the looks of it please with the steps also!
Been away for a week but guys are cracking on with the patio and doing a great job! Decided on offset bond rather than brick bond, really pleased with it. My choice to break bond behind the garage as won’t be seen and saves me some slabs/ losing more of the garden to keep bond (retaining wall would have to have been further back) Gone for mid grey grout and will use a similar colour for the decorative stones between slabs and sleepers (stones as allows sleepers to move a little and didn’t want any cuts along the back edge!
No afraid not After getting the astragal bars sorted I was told the adjustment was the best they could do so gave up
One last thing we may do is add a triangular cut of oak sleeper as the levels drop down to soften the look of the RSJ What do others think?
Ground work more or less complete bar building up the ramp in the corner to allow me to get the mower up Top soil to add to the planters and garden behind the retaining wall and a small amount of turf to feather in to the lawn All levels are ready for paving to go down Fingers crossed in about 2 weeks! Very pleased with the work
My friend is doing it as owns a ground work company He is mega fussy the same as me which is great! I sketched out what I wanted then we have just tweaked it along the way (he has sorted all materials apart from lighting) There is still a flower bed to form with oak around the stairs and main retaining wall then carry the sleepers down the far side of the house There is probably about 85m2 of limestone to lay (slabs are £38m2) Looking to bring it in around the 20-22k mark not including muck away (had 2 lorry’s so far!)
Sleepers now complete I volunteered to drill the 25mm holes for the lighting to save time, not the best of jobs and bad back in the morning! Also run all the wires between the DPM and the sleepers and added ducting to take the loom round the steps
It’s having a DPM across the back of them Will drill out the sleepers for the lights then back fill I think
