phatboy
1 Follower
Personal Information
  • Location
    Jersey
2786 profile views
phatboy's Achievements
Regular Member
Regular Member (4/5)
36
  1. No it started a few days before I posted. Had been running for 6ish years without issue. I suspect adjusting the level just temporarily resolved the issue, time will tell!
  2. I actually never did it, but I do have the bearings. My unit wasn't quite level, and when I sorted that the issue went away! 5 months and it hasn't become an issue again yet.
  3. Thanks for this. I have a Sentinel Kinetic BH unit, and it seems they need the same bearings, so I will chance it and order the same as you @DOIGAN
  4. Hi, we did go with Millboard in the end. It was hugely expensive (£8000 including fixings) for both decking and cladding. This is it, in Golden Oak: It is very nice and we are very happy with it. Spent a lot of time fitting it, as any wrong cuts were worth a lot of money! It's unpleasant stuff to work with, the resin dust is very itchy. But the results are very good, and it doesn't expand or contract in changing weather.
  5. At least I’m not going insane then! But thank you - this advice will be relevant for the other 2 bathrooms, which are having concealed valves.
  6. Thanks Nick, but I’m struggling to visualise! The shower is an exposed type (this or similar: https://www.duravit.co.uk/products/bathroom_faucets/shower_systems.com-en.html?product=7158157 ), where as your first link in my mind would be used on a recessed valve? The 135 degree, do you have a picture of this setup? My brain just isn’t doing its stuff after a weekend of bathroom building! Thanks Tim
  7. Hi all, This was super simple until I really thought about it. I am going to run my 15mm plastic Hep pipe down the wall to the shower position. The wall is concrete, so needs chasing. As the pushfit elbows are quite chunky, I will need to dig fairly deep into the wall where they go, and will use copper out of each so I can use compression on the shower unit. Is this the right approach? Chase the wall about 25mm deep for the pipe, but then increase it up to about 50 - 60mm to fully bury the elbow? Or is there some other kind of fitting I could use? I considered copper with sweated elbows, but it would mean a joint in the loft, which with the manifolds is exactly what I've wanted to avoid. Many thanks!
  8. There are a fair few extracts in the system already, so probably a supply is the best option. No wet items going in there, all nice clean stuff
  9. I hadn't mentioned, but there is an en-suite too, so having the bedroom and this wardrobe room as supply, will allow lower flow rate, whilst pushing all the air in the direction of the extract in the en-suite. So Im inclined to do the same as you - thanks
  10. Hi, We have varied from our original plans, and incorporated a walk in wardrobe off our bedroom. The room is 1.9m x 1.6m, and we are likely to fit it out with a kit like this from Ikea: https://www.ikea.com/gb/en/p/pax-corner-wardrobe-white-stained-oak-effect-s99217996/#content But.... should the MHRV in this space be a supply, or an extract? I can see the benefits to both... but am leaning toward a supply? If supply, I think fitting it close to the inside corner or the wardrobe would be best. All input appreciated Tim
  11. Maybe, as it doesn't have foil and is covered with a house wrap I suppose it can 'breathe', if that's important. When I ran out of K5, I did use half a board of foil covered board, though.
  12. They are just standard 100x50mm 2mm thick L brackets. No pics, I fitted everything within a day so was going quick! To fit them directly would have needed at least 150mm concrete screws, and quite a few of them.
  13. I did it in probably not the optimal way, but I'm OK with it. - 4x2 timbers attached to the block wall with large L brackets - Insulation packed between them (70mm K5) - Breather membrane cover - Battens 15mm thick over the top, nailed onto the 4x2s - Counter battens 2x1, painted up with Black Jack - Millboard vertical cladding
  14. Thank you, all ordered! My preferred supplier has Knaufs version, but they accept BG part numbers as apparently thats what everyone goes by
  15. Not a chance of a rep in Jersey sadly!
