DamonHD
Everything posted by DamonHD
  1. It's a Potterton Performa 24. Rgds Damon
  2. For a while now the pressure reported by the combi has been swinging between 0 and 3 bar. When it gets low I gently top it up, but I suspect a failed expansion vessel. Rgds Damon
  3. (We genuinely did have ice inside my bedroom windows until my dad did some DIY secondary glazing!)
  4. I've tried telling them about ice on the inside of the windows when I were a lad in Yorkshire, and having to walk uphill both ways, but they don't believe me! Rgds Damon
  5. Planning to add some USB heated insoles to my usual longjohns, double socks, fleece, etc. But the rest of the household may not be so keen on an Arctic re-enactment! Comments welcome! Rgds Damon
  6. I disagree. It's a complex decision, and getting it wrong will cost lots more disruption and time and money and carbon than necessary. Having people list the alternatives and pros/cons has already been helpful. I *am* also talking to several possible installers in parallel. I don't want to wait to find myself with a broken system once it's cold and there's no available equipment or installers, and/or I need planning permission that takes months (and more money). Rgds Damon
  7. Thank you so far. I've added another layer of sub-options / questions to my thinking! https://www.earth.org.uk/note-on-combi-replacement-dilemma.html#sub I can copy them in here if anyone thinks that that would be a good idea! Rgds Damon
  8. Also a possibility, but that takes space that we don't have and/or will be ugly. But it may be the best worst option... Rgds Damon
  9. That is what I would like to do. However the last gas engineer to replace the expansion vessel cursed about how the Potterton Performa 24 was laid out. It may not be possible to replace without removing the boiler from the wall, and thus disconnecting from the gas supply. At which point it may not be legal to reconnect it (non-condensing, non-boilerplus, etc) under new regs. (Also the old expansion vessel is a bit expensive and will take hours of expensive engineer time to swap out, likely.) Rgds Damon
  10. Thanks all for thoughts and suggestions so far. I have started writing it up here... https://www.earth.org.uk/note-on-combi-replacement-dilemma.html Rgds Damon
  11. That might be a good idea... Maybe you can infer what you're after from these: https://www.earth.org.uk/note-on-data.html#Unstructured
  12. (Did I remember to say that our house is very small, including the kitchen where the current boiler lives!) Thanks for the comments above: I am thinking hard about them! Rgds Damon
  13. Magic! Good heating controls, good IWI, always eg looking to buy the most efficient appliance when one needs replacing, some behaviour change, etc, etc. http://www.earth.org.uk/towards-a-LZC-home.html#todo Rgds Damon
  14. (Thanks for comments so far!)
  15. It has already had a number of repairs, and I will repair it if I reasonably can. Part of the problem is the way that this device is put together which makes the fix at the very least slow, but then also regs have changed since the last big repair was done... Rgds Damon
  16. Hi, Our old gas combi may be on its way out. Our house is due to be bulldozed in 5Y, so ASHP upgrade extra punitive. We are already a low user (<3MWh DHW and space heat per year). Winter heat demand typically 3kW, peak ~6kW. Already have a heat battery installed (Thermino). Other gas appliances long since gone. Electricity is single-phase. What would the learned mob here advise: a condensing gas combi, an electric combi, something else? Obvs, I want to minimise carbon, including embedded/upfront carbon. I'm prepared to be a bit spendy to do that. Rgds Damon
  17. PVGIS is your friend: https://re.jrc.ec.europa.eu/pvg_tools/en/tools.html#PVP Rgds Damon
  18. An update: trying to pick the best fixed export (spill-to-grid) margin for my solar PV diversion to a heat battery: https://www.earth.org.uk/eddi-diverter-export-margin-analysis.html Rgds Damon
  19. The way my system is now set up the heat store is a smalish Thermino (~2 day's DHW in a small unit under the combi) currently heated by PV diversion, but can be boosted from mains at appropriate times. The Intatec Intasol valve automatically draws water direct from the Thermino if hot enough, else via the combi (mixed down to 28C since my combi doesn't like hot input) as preheat. https://www.earth.org.uk/note-on-solar-DHW-for-16WW-UniQ-and-PV-diversion.html#2022-03-09 Gas demand has dropped from 4kWh/d to almost nothing (less than 0.5kWh/d). Rgds Damon
  20. All storage (other than the Thermino heat battery) and inverters are outside the main living space, though the inverters are in the loft which might worry some as a hazard. (I asked the London Fire Brigade to check over the system as I had it at the time and they were content.) On the other hand, my insurers won't ensure anything outside even though I did point out that for (eg) Li batteries this is (a) common and (b) safest... I managed to negotate a compromise, but it's a bit silly... Rgds Damon
  21. #NotAllLithium The bulk Lithium batteries that I have used / am using are LiFePO4 which do not tend to do most of those nasty things: AFAIK the electrolyte is the problem in Lion laptop/phone batteries. Rgds Damon
  22. FWIW I run my router (12V) off-grid (ie from off-grid PV and storage) automatically when possible. https://www.earth.org.uk/expanding-off-grid-PV-system.html Rgds Damon
  23. Interestingly, while the supply meters say my Enphase is doing that job relatively well, my Eddi metering dsiagrees quite substantially, though does its own job reasonably well. (This is the old banking joke about if you don't want to have to do reconcilliation, don't record more than one stream of numbers.) I'm starting to assemble side-by-side streams here to enable better comparisons: https://www.earth.org.uk/energy-series-dataset.html So still can't help you I think, though I am prepared to add sponsored equipment under test in principle! As to battery life, other than abuse (pushing to close to or beyond limits), I basically assume both calendar-life limits AND effective full-cycle limits (whether taken piecemeal or not) for both LA and Li chemistries. But what do I know? Rgds Damon
  24. I definitely know of one unratcheted meter that the FiT administrator has been told about that hasn't been replaced, but the system isn't big and maybe the cost of replacement was considered too high. No, it's not mine! Rgds Damon
  25. @SteamyTea Cascading system would be the right way to do it, but I suspect that many users would fail to distinguish needs from wants well. @markocosicI don't understand your question, or don't know the answer, or both! Rgds Damon
