  • entries
    3
  • comments
    5
  • views
    8568
Gooman
Because of our budget, there's some hard decisions and trade-offs to be made. Grateful for any constructive comments!
Remaining garage size
  • It's a double-length garage - 9m. We could just convert half of it, leaving the front part as a regular-sized garage, but that will leave us tight on space. Instead we're leaning towards taking around 5.5m, making the front part just a workshop and store (and hopefully, micro-brewery ?. Floor will be raised by 100mm using PIR with 18mm chipboard on top, and external walls with timber frame and PIR. Roof to be raised by our tame builder.
Shower location
  • Due to the 3-gabled chalet roof, there's not many places where a shower can be put upstairs. There's no scope for an en-suite that we can see (unless we shelled out for a dormer, which is likely to be beyond our budget). The only option for an upstairs shower seems to be to move the bathroom wall into the 3rd bedroom, making it smaller still.
  • The other option is to have a downstairs shower room in the garage, but that's then eating into kitchen/dining room space.
Kitchen/dining room configuration
  • The existing kitchen is long and narrow, but we aim to widen the room by taking out the built-in cupboards and moving the door back slighting into the hallway
  • We'll then knock through the current utility room
  • The new space is actually larger than the existing kitchen. Do we move the kitchen into the new space and have the dining room where the kitchen is? Could seem a little odd to walk through the dining room to the kitchen, plus we'd have to install a new kitchen pronto as we'd be wrecking the orginal (and that's not in our short-term budget)
  • Would like big (possibly 4m, 5 door) bi-folds onto garden, and a big (3m x 1.5m) roof lantern in new converted space on flat garage roof. Lowest u-values we can afford.
  • Leaning towards keeping the kitchen location where it is, sink relocated to window, and with a small utility room in old garage space
Insulation
  • Uninsulated concrete ground floor - which might be tricky to raise and too expensive to lower for insulation. VIPs too expensive to do throughout (but considering 10mm for kitchen)
  • Cavity walls are already insulated
  • Roof insulation needs topping up, and lap vents installing in roof fabric
Heating and hot water
  • Existing system is warm air, with electric immersion and cylinder for hot water. Boiler replaced within last 12 months, but the system can't easily be extended into the new conversion space. So we'd need a combi-boiler just for the conversion.
  • Floor drop in garage isn't enough for the insulation that would be recommended for UFH
  • House isn't well-enough insulated for ASHP
  • As a result we're leaning strongly towards simply a new modern combi-boiler and wet rads throughout
0 Comments
Recommended Comments
There are no comments to display.
