  • entries
    25
  • comments
    176
  • views
    39065
Entries in this blog
Side Extension moving along, slowly but surely
Just a few progress photos of the inside and how its been moving along since the builders left after completing their work:   First job was the warm roof, literally just to get some of the 100mm boards used up as i had no where else to put them         I was also trying to get as much of the dusty bits out of the way before opening this room up to the rest of the bungalow, so removed the outer bricks from under the bathroom window (the blocks will b
MikeGrahamT21
MikeGrahamT21 in Side Extension
Extension completed on the outside
What a journey that was, lying builder and a few no show days caused the finish date to slip, and following a 2month delayed start, but I got there in the end!! Good things come to those who wait eh.   So the outside shell of the building is now completed, and yesterday I started work on the inside.     The lean-to roof was extremely close, but just squeezed it in with a slight pitch modification. This leaves me with essentially 3 sections of wall to clad: Near sid
MikeGrahamT21
Finally got started on the extension!
So after 2 years since the planning permission was granted, and a 2month delay from the builders I'm finally underway on what will be the last major building work on this bungalow.                   Having real trouble finding a joiner who's available to do the roof, so I may end up having to do that myself. The one bit i'm unsure on having never done a lean-to roof before, the wood plate which goes
