Roz Posted May 7, 2019 Share Posted May 7, 2019 When looking for espagnolette handles for our casement windows, this stock image popped up. I like the turning idea instead of a hanging handle, and wondered if anyone had come across any like this that might be what I'm after? Link to comment Share on other sites More sharing options...
Temp Posted May 7, 2019 Share Posted May 7, 2019 Be careful on double openers the two handles don't foul each other. Link to comment Share on other sites More sharing options...
Temp Posted May 7, 2019 Share Posted May 7, 2019 Jim Lawrence stuff looks similarly elegant but I couldnt see a window latch like that on their web site. https://www.jim-lawrence.co.uk/window-latches Link to comment Share on other sites More sharing options...
jack Posted May 7, 2019 Share Posted May 7, 2019 You see these all the time in France. Maybe try one of the big French DIY places online? 1 Link to comment Share on other sites More sharing options...
Temp Posted May 7, 2019 Share Posted May 7, 2019 Think they are called window T handles. https://www.interiorhardware.com/window-hardware/tilt-and-turn-handles/tilt-turn-window-handle-stainless-steel-85mm-8520830mrs.html https://www.interiorhardware.com/window-hardware/window-handle/window-handle-t-brushed-nickel-with-antique-white-porselein-110mm-1340110agn.html 1 Link to comment Share on other sites More sharing options...
craig Posted May 7, 2019 Share Posted May 7, 2019 Be careful, if your looking at using them, your building control officer is unlikely to sign them off. First, check you’ll get approval from building control officer, 2nd your insurance company and 3rd they’ll work with the windows. Link to comment Share on other sites More sharing options...
Roz Posted May 8, 2019 Author Share Posted May 8, 2019 15 hours ago, craig said: your building control officer is unlikely to sign them off. Thanks Craig, what's the reason for that if they are espag fitting? Link to comment Share on other sites More sharing options...
Roz Posted May 8, 2019 Author Share Posted May 8, 2019 15 hours ago, Temp said: Think they are called window T handles. https://www.interiorhardware.com/window-hardware/tilt-and-turn-handles/tilt-turn-window-handle-stainless-steel-85mm-8520830mrs.html https://www.interiorhardware.com/window-hardware/window-handle/window-handle-t-brushed-nickel-with-antique-white-porselein-110mm-1340110agn.html Thanks a lot Link to comment Share on other sites More sharing options...
