Buster Posted March 28, 2019 Posted March 28, 2019 So as discussed on earlier thread I have put my planning application in to remove a single condition on my new build. the problem is it was condition 4 on my original permission, when I requested a variation on another condition which was approved the same condition appeared as condition 3. if that makes sense so yesterday when I applied for removal of condition i put condition 3 on planning number ,,,,,,, and condition 4 on planning number ,,,,,,, today recieved an email asking which one I wanted to remove as both can’t be on one application, even though it’s the same condition? so do I really have to submit another or just mention the original permission which will then knock on to the one after? nothing is ever simple in planning!
ProDave Posted March 28, 2019 Posted March 28, 2019 Surely the latest one? For the avoidance of doubt I would quote the full text of the condition you want removed. 1
Buster Posted March 28, 2019 Author Posted March 28, 2019 Yup thanks I quoted it and put 213/215 cond 4. And 983/216 condition 3, they are the exact same condition. the second just appeared on a variation of a condition application, pointless really it just copied all the conditions of the original pp.
AliMcLeod Posted March 29, 2019 Posted March 29, 2019 (edited) I'm not sure what original thread you're referring to so its not clear if you currently have one or two applications in flight. If two, and your original application still live, do you want to keep it live and amend it? If so, I wonder if you're being told that you have to apply for two amendments, one for the original application and one of the new one. If you just have one application in flight, then surely you should only reference that? Edited March 29, 2019 by AliMcLeod
Buster Posted March 29, 2019 Author Posted March 29, 2019 14 minutes ago, AliMcLeod said: I'm not sure what original thread you're referring to so its not clear if you currently have one or two applications in flight. If two, and your original application still live, do you want to keep it live and amend it? If so, I wonder if you're being told that you have to apply for two amendments, one for the original application and one of the new one. If you just have one application in flight, then surely you should only reference that? My build finished 2 years ago on the original plan in 2015 there was removal of pd rights during the build we varied a condition that was about use of garage as a workshop, as we had to submit an app for this it was granted but the conditions from the original pp were copied over. so now 2 years later I’m after removal of a condition on the original pp but it also appears on the subsequent variation application. when I referenced these I was told which one do I want to challenge as I can’t do both on one application. does this mean I need to pay £250 again to list the same. Condition separately? or would a removal on the original plan permission null the later one?
Mr Punter Posted March 29, 2019 Posted March 29, 2019 If you just use the second one it will be OK as that is the one you implemented. Confirm it with a letter attached to the application. 1
Buster Posted March 29, 2019 Author Posted March 29, 2019 Thanks yes the most recent one was the answer finally got an answer from planning
Buster Posted May 17, 2019 Author Posted May 17, 2019 Well time is up decision will be made by next Friday met the planning officer today she seemed nice so fingers crossed.
