Morning,
With regards to PIR insulation when placed under floor, does it matter about being foil faced?
My floor will be concrete slab / DPM / 120-150mm PIR / UFH pipes / 75mm concrete screed.
If the answer above is yes, is there anything I could use on top of the PIR to replicate the foil face, like an aluminium VCL like this?
Thanks
I've repaired damaged foil faced pir with heavy duty Bacofoil before. Bit of spray adhesive, job done.
Nope. Just put a thin plastic slip membrane between the insulation and the concrete.
That's what I am hoping, I'd be able to reduce the cost of insulation quite a bit by going without foil.
DPM above and below - use 25mm of EPS below the first DPM instead of sand blinding, then pack the PIR in, second DPM and job done ...
What's the thinking behind the double dpm? Just to save on messing around with blinding?
1 hour ago, A_L said:
No, there is a danger that the insulation will undergo hydrolysis (breakdown to its constituent chemicals) in permanently damp/wet conditions.
http://blog.celotex.co.uk/technical/what-celotex-insulation-can-be-used-in-floor-applications/
Sorry I got confused as I misread Peters post.  Yes dpm then PIR then another dpm to protect from screed.
Why the recommendation of 25mm eps instead of blinding?
16 minutes ago, PeterW said:
It’s just easier than sand blinding and protects the DPM from punctures.
Thanks.  I'll see what depth I have as the hardcore is in and compacted but I can't remember what depth I have left to the FFL.
