I have to make a new opening for the front door of a small barn conversion. This has to be done now before I actually have a door/frame because I am insulating below slab.
I don't know yet whether I will buy a new door, get one from ebay or get one made by a friend locally but think I should make it a generic size so I can most likely avoid problems later.
Looking at some websites it appears 838mm is a pretty standard size and the one I rang up said that their external door frames add an extra 70mm.
Should I add on another 15mm so set the opening at 923mm? Less, more? Is 35mm for a frame edge pretty standard?
I am planning on making a temporary frame to build around.
Any other advice appreciated.
A 910 opening to accommodate a 900 frame 838 door size
Probably the most common door size Add 100 mill for disabled access
