1 hour ago, saveasteading said:
That sounds complicated and the effluent would go untreated if there was any problem, whereas the 3 chamber types work to a high % of optimum without power.
you'd need to have a problem for quite a long time as there's 400mm or more between the normal level it pumps out down to, and the "overflow" height.
9 hours ago, Kelvin said:
Yes, our Graf One2Clean has a built in sampling chamber and the treatment plant wasn’t too dear so simplified the install with no extra cost.
Hi Kelvin, my tank is a One2clean. Is yours the standard version? Mine is not the plus version.
Thanks for all the reply’s. Fingers crossed my tank also has a sampling chamber il take a look tomorrow. This could say a lot of headaches.
That will be about 1m3 at a guess. or 7 person.days.
Then what comes out? Is it partially treated, or is there a baffle system to hold the worst of it?
Good Q. The inlet pipe is plumbed right to the bottom on these and there's only a small overflow hole toward the top of the sampling pot. We had an issue with the pump last year which had it out of action for a  week or so. At no stage, running or not, have I ever seen any floating scum layer.
I've been advised by the reps of two different distributors that even a couple of weeks without power won't affect the output quality of a mature plant noticeably
