dnoble Posted February 20, 2019 Posted February 20, 2019 I have a long (55m) run from house to mains sewer in road We laid 110mm pipes with appropriate drops (for foul and surface/roof water) next to each other in trench. Building inspector checked and said fine. Called next day and said " by the way you need an inspection chamber every 22m" (therefore 2 and need to include both pipes). This is going to be very fiddly to retrofit (builder hadn't done a run this far before and didn't know of this rule) Also inspection chambers all seem to have radial pipe entrance. I need one 300-500mm accross with 2 parallel pipes in the bottom. I cant find such a thing online. Is the only option building one out of blocks or something??
Jeremy Harris Posted February 20, 2019 Posted February 20, 2019 A quick search seems to throw up several with opposing inlet/outlets: https://www.plasticdrainage.co.uk/cs320-inspection-manhole-chamber-set.html https://www.drainagepipe.co.uk/products/complete-inspection-chamber-sets/300mm-mini-inspection-chamber-complete-set-unique/300mm-mini-inspection-chamber-complete-set/ maybe two of the smaller ones can be set side,by side, offset down the run by a metre?
Jeremy Harris Posted February 20, 2019 Posted February 20, 2019 Just seen this, the image on the top left on the Polypipe website:https://www.polypipe.com/inspection-chambers Might be able to get two of those almost side by side.
Mr Punter Posted February 20, 2019 Posted February 20, 2019 I understood that it was 45m between inspection chambers. I also think you could just put a rodding eye for the foul and not bother with the surface water. Ask Marley or Polypipe technical for backup if required. Easier to send them a drawing than mess with digging up drains.
dnoble Posted February 20, 2019 Author Posted February 20, 2019 Hi Jeremy, thanks. That last one looks like a possibility if they are building regs passable. Yes otherwise the offset option squeezed in might work, though you'd have to chop a bit out to accommodate the uninspected pipe
Jamie998 Posted February 20, 2019 Posted February 20, 2019 23 minutes ago, Mr Punter said: I understood that it was 45m between inspection chambers. I also think you could just put a rodding eye for the foul and not bother with the surface water. Ask Marley or Polypipe technical for backup if required. Easier to send them a drawing than mess with digging up drains. I agree - I am pretty sure 45m from IC to IC. Table 13 of Part H.
dnoble Posted February 20, 2019 Author Posted February 20, 2019 Th ebuilding insepctor was pretty clear you needed one for any run over 22m. Could you provide a link? I've just looked at table 13 part H it isn't very obvious what applies to me. It mentions 22 and 45m https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/442889/BR_PDF_AD_H_2015.pdf
LA3222 Posted February 20, 2019 Posted February 20, 2019 1 hour ago, dnoble said: Th ebuilding insepctor was pretty clear you needed one for any run over 22m. Could you provide a link? I've just looked at table 13 part H it isn't very obvious what applies to me. It mentions 22 and 45m https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/442889/BR_PDF_AD_H_2015.pdf On the left hand side of that table you have a list of various access points....along the top you have the lost of 'to' access points. So....inspection chamber shallow 'to' inspection chamber is 45m. Not trying to be patronising...thats how I read the table. Maybe others read it differently? I'm not sure how IC to IC is ever 22m?
