Hi All,
On my extension plans the wall for my garage is showing an open cavity (Brick and Block wall) in the opening for the garage door.
I presume that this would normally be finished with a cavity closer and then the door fitted in the opening.
However I may want to fit the door behind the opening to allow for extra headroom (Insulated Roller Door)
Is it possible to close the cavity if I fit the door behind the opening without creating a cold bridge?
Thanks, Wozza.
Edited by wozza
If it's an open cavity, without any insulation, is cold bridging even an issue?
ps. If I were building a new garage I'd insulate the hell out of it. My 1970s garage if freezing in winter and not a nice place to work when it's cold.
Edited by Triassic
When I say open cavity, I mean that it is intended to be closed with a cavity closer that would normally be hidden by the door frame.
But if I fit the door behind the opening then the cavity closer will be seen / exposed to the elements.
