Pete Posted January 31, 2019 Posted January 31, 2019 Fitting my vent terminals for my Mvhr supply and extract valves and I know a few on here have used BPC for the ducting etc. When cutting the plenums down to size, the bit that sticks through the plasterboard that the ceiling valve pushes into, have people left them to protrude a little bit lower than the plasterboard? It is just when I looked at how the valve attaches to the plastic tube it needs to compress a foam gasket and I assume for this to work properly it would need the tube to be left longer than the flat surface of the p/board to make a snug fit? TIA
j_s Posted January 31, 2019 Posted January 31, 2019 We cut them so when the ceiling was plastered it was flush with the plenum. Valves are tight on the plenum so it seems ok how we've done it
Roundtuit Posted January 31, 2019 Posted January 31, 2019 I left them full length when fitting, and just made sure I taped any airtightness membrane above what would be plasterboard level. The plasterers boarded and plastered round them, and I cut off the excess with a multitool when the plaster was dry, leaving them flush with the ceiling. Simples!
