I bought this bath waste: http://bathsupermarket.com/pop-up-bath-waste-for-traditional-freestanding-bath
It's 35mm - does anyone know where I can get a 35mm to 40mm flo plast solvent weld adaptor or a compression fitting?
I need to extend the short stub of 35mm chrome waste into a trap under the floor and then boss that in to 40mm solvent weld. I can't seem to find anything online...
Thanks!
Edited by iSelfBuild
So that's because it's probably not designed to be used with plastic ...
35mm is a standard copper size, and I expect they would be looking to use a chrome downstand on it. You can buy short lengths on eBay Try this
You'll then need to convert it to a standard size - Floplast do a universal compression fitting that should work
Yep should work - there is a non compression version that just uses a thick rubber gasket but I'm not sure how long that would last ..!
