Big Neil Posted November 19, 2018 Share Posted November 19, 2018 So lets say you have either an integral or attached garage. Does it make sense to plan in some space within it so you have a wall with everything on. Sort of like a dedicated plant room but just a wall in the garage. Everything this is, water cylinder, consumer unit, UFH manifold at least for the downstairs and maybe other bits i haven't thought of. I'm just thinking in terms of saving inner space where possible. Likewise how many of you guys have wired all your telecoms/network bits to a little patch area likely in the loft, and then do with access points to get wi-fi signal in the living areas? 1 Link to comment Share on other sites More sharing options...
ProDave Posted November 19, 2018 Share Posted November 19, 2018 Careful with your hot water tank positioning. imho that does not normally belong in a "plant room" unless your plant room is in the middle of the house. It needs to be central to all the rooms that use hot water. Mine has ended up in what will be an airing cupboard from the small bedroom as that was the most central location. My telecoms / network / AV stuff is in the cupboard under the stairs. Wifi hub under there gives a workable signal in all rooms, but again the stairwell is central to the house. UFH manifolds need to be central to the rooms they are serving to minimise pipe runs. Link to comment Share on other sites More sharing options...
Big Neil Posted November 19, 2018 Author Share Posted November 19, 2018 Thanks @ProDave. So there might be a saving if there is an integral garage where one edge of the garage is near the centre of the house, but otherwise, the idea is try and be clever with the spacing. So maybe UFH manifold for downstairs in cupboard under the stairs and maybe in the loft for the upstairs rooms. Silly quewstion maybe, but other than having a shorter pipe run, what reason is there to centralise the cylinder for rooms (UFH aside) using hot water? I guess i get it for the UFH, but i can't see why it makes a difference for hot water outlets.. Link to comment Share on other sites More sharing options...
ProDave Posted November 19, 2018 Share Posted November 19, 2018 The issue with the hot water is the length of tome it takes for hot water to reach the tap when you turn it on. Unless you have a pumped recirculating hot water loop. Link to comment Share on other sites More sharing options...
