daiking Posted November 18, 2018 Posted November 18, 2018 All the ‘trade’ (£1 ish) caulk I’ve used has shrunk and cracked. Are some of the £2-3 tubes significantly better in this respect?
nod Posted November 18, 2018 Posted November 18, 2018 5 hours ago, daiking said: All the ‘trade’ (£1 ish) caulk I’ve used has shrunk and cracked. Are some of the £2-3 tubes significantly better in this respect? Great minds Ive tried better quality caulk About the same as the quid ones
Oz07 Posted November 18, 2018 Posted November 18, 2018 Dunlop was recommended on the job im on. Has still cracked although only has wall paint on atm. Perhaps the oil based will fill these cracks and stay good?!
daiking Posted November 18, 2018 Author Posted November 18, 2018 6 hours ago, nod said: Great minds Ive tried better quality caulk About the same as the quid ones My fault for trying the caulk the grand canyon many times. I got a couple of tubes of no nonsense anti-crack caulk as I was at Screwies not Toolies. I await to be disappointed in a years time.
Nickfromwales Posted November 18, 2018 Posted November 18, 2018 Misuse of caulk by the sounds of it. Caulk is not for gap filling, that’s what filler is for Caulk is for fine work, but if you do need to fill the San Andreas fault then fill it and leave the caulk to shrink back ( it reduces as the moisture leaves ) and then go over it again a couple of days later.
daiking Posted November 18, 2018 Author Posted November 18, 2018 3 minutes ago, Nickfromwales said: Misuse of caulk by the sounds of it. Obvs
Nickfromwales Posted November 18, 2018 Posted November 18, 2018 30 minutes ago, daiking said: Obvs I was bored ?
