Freeing a stuck velux
Guest Alphonsox
I've just tried to open a centre pivoted velux in our loft space and it's stuck solid. The bottom seemed happy to move a bit but although the airvent/opener handle moves the window doesn't. I can only assume the catch or hinges are sufficiently corroded to have jambed the whole thing shut.
The windows itself is probably 30yrs old and hasn't been opened for at least five years. It is virtually impossible to access from the outside (at least I'm not going to attempt it)
Any ideas how I can get this to open again ?
Guest Alphonsox
17 minutes ago, ProDave said:
More likely the seals have stuck. I can't see the hinge mechanism seizing to the point the window will not open.
Good thought - Any ideas how to get them freed-up ?
Guest Alphonsox
1 minute ago, Declan52 said:
Wd40 and let it soak in.
Good - that's pretty much what I've done assuming I can get the WD40 anywhere near the seals from the inside.
Guest Alphonsox
4 minutes ago, Declan52 said:
Have you the red straw extension so you can direct it exactly where it needs to go.
Yep - Fully strawed and sprayed into the gaps - but its not obvious it's actually getting to the seals.
