Tony K Posted October 16, 2018 Author Posted October 16, 2018 3 minutes ago, JSHarris said: The Party Wall Agreement is a good point, that close and it may well be required as the 45 deg rule means that the horizontal distance in from the bottom of any foundation system is going to project a fair distance over the boundary. Mini piles will be used with a slab on top so shouldn't be an issue.
Jeremy Harris Posted October 16, 2018 Posted October 16, 2018 12 minutes ago, Tony K said: Mini piles will be used with a slab on top so shouldn't be an issue. Doesn't that depend on how far away any structure is on the neighbours side, though? I had a feeling that consent or notice was still required even with relatively benign piling systems like screw piles.
Tony K Posted October 16, 2018 Author Posted October 16, 2018 1 minute ago, JSHarris said: Doesn't that depend on how far away any structure is on the neighbours side, though? I had a feeling that consent or notice was still required even with relatively benign piling systems like screw piles. I think it's only if their foundation is close by rather than their land.
Jeremy Harris Posted October 16, 2018 Posted October 16, 2018 8 minutes ago, Tony K said: I think it's only if their foundation is close by rather than their land. Yes, it normally only applies to structures, so if there are no structures within the proscribed distance ( a 45 degree line drawn outwards from the lowest point of the foundation system) then I think you're in the clear. As @PeterW says, though, you're either going to have to get the neighbours permission to erect scaffolding on his land or just trespass and hope that he doesn't materialise and force you to remove it.
Tony K Posted October 16, 2018 Author Posted October 16, 2018 1 minute ago, JSHarris said: As @PeterW says, though, you're either going to have to get the neighbours permission to erect scaffolding on his land or just trespass and hope that he doesn't materialise and force you to remove it. Shouldn't need to. It's single storey and that wall will be blocks laid over hand from my side.
PeterW Posted October 16, 2018 Posted October 16, 2018 Can’t see how you can fit verge, gutters or anything else on that side from a 10” gap..? Is now the time to get to know the neighbour properly if you’re going to be there for some time ..??
Declan52 Posted October 16, 2018 Posted October 16, 2018 28 minutes ago, Tony K said: Shouldn't need to. It's single storey and that wall will be blocks laid over hand from my side. You will need scaffolding to put on the roof and tile it. If the gable is at the side beside the tree you will need scaffold for it as well.
Tony K Posted October 16, 2018 Author Posted October 16, 2018 1 hour ago, PeterW said: Can’t see how you can fit verge, gutters or anything else on that side from a 10” gap..? Is now the time to get to know the neighbour properly if you’re going to be there for some time ..?? I know him well enough already to be making arrangements which don't rely on his cooperation! The land came with our house, we've lived here for 15 years, he lives miles away and rents it out. Limited access for bits of roofing is something I can work out with the tenant if need be.
scottishjohn Posted November 13, 2018 Posted November 13, 2018 now i don,t about english law ,but in scotland anything hanging over from nieghbour you can cut off . so maybe you cut off the roots on your side of boundary and build foundation at least at that point down to below where roots are ?. in scotland you cannot build within 1 m of boundary as well -- So i am suprised you can even build within 10" anyway
