IIRC, the 3 phase models were late to shift to inverter control.  This makes sense, as an inverter controlled unit has a three (sometimes more) phase motor.  They rectify the incoming AC to DC, then drive the multi-phase motor with the inverter drive, which is really a variable frequency AC drive.  For a 3 phase inverter controlled unit, the 3 phase would be rectified to DC, then used to drive the motor variable frequency inverter.   From the symptoms described, with a shorted motor phase, it sounds like direct AC drive to me.  One "feature" of variable frequency drives is that they rarely, if ever, damage the motor; the electronics in the drive unit tends shut down a hell of a lot faster than a motor under fault conditions, and will usually just instantly fail.
I've built a lot of variable frequency motor drives, for things like my electric motorcycle, electric bikes and an electric boat and have yet to damage a motor (and all my motors are three phase machines in essence).  I've blown a fair few motor controllers, though, until the current generation, where there is so much protection built in that the controller just shuts down within a µs or two if a problem develops (or if I do lunatic things on the motorcycle - hard not to when you have 100% torque at zero rpm...).
I got hold of the model number. According to the data sheet it's inverter driven (note: I may have been misremembered the comment about the short circuit being on one coil):
If the vfd goes t!ts up can't it become a regenerative load itself? RCD won't protect against the resultant overvoltage.
Appendix 16 of the latest regs,  p507 onwards goes into detail about SPDs in some detail with lots of diagrams depending on the earth arrangement.
Thanks for that.
I think they're about to become effectively compulsory in many installations, so my electrician had already been reading up on them.
Suspect this job brought forward his study a bit!
  On 12/10/2018 at 13:06, jack said:
Thanks for that.
Expand
Maybe worth delving into the section on lightning protection zones too?
Nick, with his eidetic memory will be able to reel off the relevant sub sections shortly! :)
Expand
Yep, he's been through all that - that's the type 1, type 2 etc stuff, right?
Expand
Circular diagram, left hand page...not got it in front of me! :)
