Alex Posted September 18, 2018 Posted September 18, 2018 Hi all, just wondering whether anyone has sourced Oak stair treads and have any recommendations. I'm building my own open riser staircase and need 12 x 60mm treads. Have talked to a couple of local joiners down here (Devon) and have got wildly differing quotes or aren't interested in quoting which I find odd! thanks Alex
MikeSharp01 Posted September 19, 2018 Posted September 19, 2018 (edited) I did a load of work on some 60mm thick oak treads for a friend they were green oak and I used the cnc machine I have access to so as to put pockets in the bottom and drill fixing holes. It worked out very well once he had put them all up and he dud expect some splitting to make them more rustic. Edited September 19, 2018 by MikeSharp01
ultramods Posted September 19, 2018 Posted September 19, 2018 I was talking to a cabinet maker about oak treads for my cantilevered stairs. He recommended not using solid oak in case it craves or distorts over time. instead he recommended some sort of engineered board such ask oak veneered ply. You might be OK as your treads are thicker (the cantilevered stairs ones are essentially a hollow sleeve that slots onto the steel tread. Have you looked on ebay?
Alex Posted September 19, 2018 Author Posted September 19, 2018 I have found a joiner on ebay whose price is similar to other quotes (approx £95 a tread) and uses engineered oak treads. pictures look ok but I'm always nervous when using ebay!! especially when its spending nearly £1500 on treads and apron and delivery...
worldwidewebs Posted September 19, 2018 Posted September 19, 2018 We bought ours from Sutton Timber in Suffolk and then had them treated with the same process as the flooring
