ToughButterCup Posted September 18, 2018 Posted September 18, 2018 You'll know that the one thing that characterises our build is interruption and delay. Getting fed up it with now to be honest. Main roof is nearly done - just the flat roof to do and we'll be water tight. I seem to have timed the flat roof build perfectly to coincide with the onset of the bad weather. The end in mind is to make sure that rain doesn't stop play while building the flat roof. So, a design for a plastic canopy is bubbling away in what , for me, currently passes for a brain. The design: a series of five 25mm plastic water pipe hoops attached to the wall held in place by a temporary wall plate at the top a vertical scaffold tube at the bottom (the poly pipe simply slots in to it - secured by a screw), and two wooden purlins to keep the hoops apart and steady - about a third from the top and bottom Its how to keep a grip on the plastic at the top and bottom that's exercising my little grey cells. Until I saw this.... Wiggle wire Further digging came up with Poly Track, Agra Lock and others. Any of you farmers out there who have experience with Wiggle Wire? Any gottchas ?
MikeSharp01 Posted September 18, 2018 Posted September 18, 2018 You can find it here: http://www.northernpolytunnels.co.uk/w-wire-wiggle-wire-polythene-fixing-system.html
ToughButterCup Posted September 18, 2018 Author Posted September 18, 2018 The link works now. Anyone know whether its any good?
Construction Channel Posted September 18, 2018 Posted September 18, 2018 sounds expensive to me, couldnt you wrap the roll the edge over a batten a couple of times then screw a second batten to the other clamping it? i know you like your wind up there so you might want to be careful creating a big sail with the bad weather coming.....
