Barney12 Posted July 20, 2016 Posted July 20, 2016 This is probably a really daft question but is there a rule of thumb as to how much volume/weight of hardcore comes from demolition? our local 'digger man' who I know and trust has agreed to demolish our old house with his 20t digger. He'll also remove all footings using a pecker as required. he's also said that he can "munch" (technical term) the blocks/concrete/bricks down to roughly 4" (in old money) using a bucket crusher. ideally I don't want any muck away and we have plenty of land to loose it on and quite a few landscaping levels to create. But how do I work out what volume I'll end up with?
ToughButterCup Posted July 21, 2016 Posted July 21, 2016 Here you are Barney. Not exactly what you need but nearly....... Using a simple sensible guesstimate of the raw volume of material in situ, the Excavated Material calculator is closest to what I think you may need.
Barney12 Posted July 21, 2016 Author Posted July 21, 2016 16 minutes ago, recoveringacademic said: Here you are Barney. Not exactly what you need but nearly....... Using a simple sensible guesstimate of the raw volume of material in situ, the Excavated Material calculator is closest to what I think you may need. Ideal. Thank you.
Barney12 Posted July 21, 2016 Author Posted July 21, 2016 27 minutes ago, recoveringacademic said: Is the cheque in the post yet? Ran out! Ecologist and LPA have them all 1
jack Posted July 21, 2016 Posted July 21, 2016 16 minutes ago, Barney12 said: Ran out! Ecologist and LPA have them all I remember this bit. Everyone wanted around £1000 every time we needed anything doing (and sometimes several rounds of £1000). Wait until the next bit when everyone starts wanting £5k every time you need something doing - and then the £20k round that follows!
ToughButterCup Posted July 21, 2016 Posted July 21, 2016 25 minutes ago, jack said: Wait until the next bit when [...] - and then the £20k round that follows! Foundations: piles and ring beam - roughly £20k
jack Posted July 21, 2016 Posted July 21, 2016 1 minute ago, recoveringacademic said: Foundations: piles and ring beam - roughly £20k Yep!
