8ball Posted August 16, 2018 Share Posted August 16, 2018 Hello guys, I have installed my own kitchen apart from the cabinet draw fronts and doors which I am currently working on but they will need painting/spraying. In the past I made some plantation shutters and used rustins MDF sealer then Rustins MDF primer and for the top coat I used 2/3 coats of Duluxe Diamond, they came out really well but I am looking for a paint finish that is a bit more hard wearing for the kitchen. I was thinking about using some kind of clear top coat that would give another layer of protection to the paint but its hard to work out if clear top coats will actually effect the paint layer underneath due to reactions in the compounds of the products. Also I am seeing that it would be a waste of time using an expensive paint such as Duluxe Diamond if its going to be covered with a clear top coat over it, surely the top coat does all the work of protecting so the paint underneath can be a lesser quality paint than D Diamond. I would appreciate any advice as I really don't have that much experience of creating a resilient paint surface. Cheers ? Link to comment Share on other sites More sharing options...
PeterW Posted August 16, 2018 Share Posted August 16, 2018 Dulux have just changed the name of their Diamond range so its appearing in the clearance places. I've bought 5l of Diamond Satinwood for £40, instead of the £92+VAT that it is in most places... 1 Link to comment Share on other sites More sharing options...
8ball Posted August 16, 2018 Author Share Posted August 16, 2018 29 minutes ago, PeterW said: Dulux have just changed the name of their Diamond range so its appearing in the clearance places. I've bought 5l of Diamond Satinwood for £40, instead of the £92+VAT that it is in most places... Its a really really good paint just need to make it a bit tougher for the kitchen. Link to comment Share on other sites More sharing options...
Onoff Posted August 16, 2018 Share Posted August 16, 2018 You can have mdf powdercoated... 1 Link to comment Share on other sites More sharing options...
8ball Posted August 16, 2018 Author Share Posted August 16, 2018 4 minutes ago, Onoff said: You can have mdf powdercoated... I'm too tight to splash out that kind of cash ? Link to comment Share on other sites More sharing options...
