Pocster Posted August 12, 2018 Posted August 12, 2018 Hey all My block paving is causing issues . Because I’ve got walk on sky lights on a slope - it makes things tricky ! ( other complications also ! ) Essentially though the pavers slope down away from the house they will be about 20mm above dpc . Is the best solution just to do a chemical dpc 150mm above them into the wall blockwork ? Are chemical dpc’s As good as ‘physical ‘ ones ?? Struggling to find another solution ....
Pocster Posted August 12, 2018 Author Posted August 12, 2018 8 minutes ago, PeterW said: Gap with a French drain of 20mm stone So if I embbed say a length of gutter ( for example ) along my wall above dpc ; with a fall - just fill with 20mm chippings ? that simple ??? ?
PeterW Posted August 12, 2018 Posted August 12, 2018 Needs to be below the DPC so any water drops below it
Pocster Posted August 12, 2018 Author Posted August 12, 2018 4 minutes ago, PeterW said: Needs to be below the DPC so any water drops below it I see . so my ‘channel’ is as deep as I need it so it’s benath dpc . My channel chippings though I can fill up to level with pavers and therefore above dpc ? . If that makes sense !!! . I’m probably worrying over nothing as this blockwork is external skin to timber frame . I worry more than @Onoff if I’m honest ..... ?
Onoff Posted August 12, 2018 Posted August 12, 2018 @PeterW, would you line the French drain first with something permeable but tough like landscape fabric?
PeterW Posted August 12, 2018 Posted August 12, 2018 French drain is a French drain .... don’t need to line them but some people like to ..
Ferdinand Posted August 12, 2018 Posted August 12, 2018 (edited) 2 hours ago, Onoff said: @PeterW, would you line the French drain first with something permeable but tough like landscape fabric? The reason for wrapping up your clean gravel in landscape fabric in a French drain, including over the top, is to help prevent it getting clogged up with small particles and maintain better performance for longer. F Edited August 12, 2018 by Ferdinand
Onoff Posted August 12, 2018 Posted August 12, 2018 8 minutes ago, Ferdinand said: The reason for wrapping up your clean gravel in landscape fabric in a French drain, including over the top, is to help prevent it getting clogged up with small particles and maintain better performance for longer. F My understanding, from a thread on here not that long ago, was that the 20mm stuff gets wrapped to stop clogging but NOT the decorative top layer of gravel. That can be periodically shovelled out and cleaned / replaced. ???
Ferdinand Posted August 13, 2018 Posted August 13, 2018 12 hours ago, Onoff said: My understanding, from a thread on here not that long ago, was that the 20mm stuff gets wrapped to stop clogging but NOT the decorative top layer of gravel. That can be periodically shovelled out and cleaned / replaced. ??? That's how I do it. But I would not normally wash the decorative stuff on top - why do that? The Franch Drain is there to take the water away.
Onoff Posted August 13, 2018 Posted August 13, 2018 12 minutes ago, Ferdinand said: That's how I do it. But I would not normally wash the decorative stuff on top - why do that? The Franch Drain is there to take the water away. I just meant if it gets leaves/moss/bits of twigs in the gravel.
trowel Posted September 16, 2018 Posted September 16, 2018 well ideally you should be 2 courses below damp and i would recommend some acco channel or similar brand ,which will contain the water far better than a piece of guttering which can easily bend or distort .
