jpinthehouse Posted July 16, 2018 Posted July 16, 2018 Hi Just about to start looking at mvhr supplier, any recommendations and which system. House is 310sq m . Integral garage, two ensuites,one bathroom,one cloakroom. Thanks John 1
PeterW Posted July 16, 2018 Posted July 16, 2018 Utility ..? Open plan kitchen..? Normal ceiling heights ..?
jpinthehouse Posted July 16, 2018 Author Posted July 16, 2018 Hi Utility rm,open plan kitchen dinner and normal ceiling height John
Jeremy Harris Posted July 16, 2018 Posted July 16, 2018 Really need to know two things: The house total volume (as it's volume, rather than floor area, that determines the capacity of the MVHR). If the ceiling heights are "standard" then this can vary from around 2.3m to 2.5m, but assuming 2.4m ceiling height then you're looking at a total volume of around 744m³. The other question is do you want a standard MVHR or one with integral comfort cooling? The latter is an expensive option and there are, IMHO, better ways to get comfort cooling than using the MVHR. To meet building regs background ventilation you're going to need a unit that can trickle ventilate at around 335m³/hr, and boost to around 2 to 3 times this figure.
jpinthehouse Posted July 16, 2018 Author Posted July 16, 2018 Hi Ceiling height 2.3 and not to bothered about the cooling side of it John
lizzie Posted July 16, 2018 Posted July 16, 2018 1 hour ago, jpinthehouse said: Ceiling height 2.3 and not to bothered about the cooling side of it In my case the supplier calculated what I needed for my house. All the ones I had quotes from worked it out from the drawings I sent them I didn't have to calculate anything. The one I chose suggested the right size and designed the whole system. As part of their service after installation they come and check the calibration (using the cone?) and make any adjustments on the unit. I can run it from an app on ipad and phone as well as from the unit itself. I made a tick box list of things I wanted my system to have (radial not branch, anti bacterial pipes, easy access filters, ultra quiet etc etc) and that is what made the choice for me, it was not only price. TBH I don't think a cooling facility would have done much to help with my overheating that is a glazing issue. I went for a Robbens Frankische system with Profi air unit and I am very happy with it all and the service both from the supplier and the installer.
