Rainwater drainage runs
Vijay
A job I totally forgot to do was the drainage runs for my guttering to my RWH.
I assume everything is done in 4" underground pipe the same as my foul drainage, but do I need inspection/rodding chambers at all, say on bends for any reason, seeing as it's just rainwater?
Cheers
Vijay
Mine has been designed with rodding points at the far end so you can give it a push through
you will get a fair bit of sediment from the roof
dust of tiles, bird poo, leaves.
No ic at bends but definitely a way to get in it
I think you can nominate to use bottle gullies with rodding points, but they are a pain to get a rod into
but then again you can always use a high pressure hose
