Thinking of doing a retrospective water heating system in a kitchen, but don’t want to increase the overall floor level, someone has mentioned a company that cuts channels into the top of an existing slab [hyperlink removed by moderator] has anyone had any experience with this type of installation, and any ideas of how efficient it is compared to an in-screed system.
If you just put water pipes into en existing un insulated screed it will be pretty ineficcient with most of the heat going down into the ground.
I'd have to agree with @ProDave, with no insulation under the screed/slab it will waste more heat than it delivers to the room.  As a guide. underfloor heating needs better underfloor insulation than normal heating, because the floor surface will be a fair bit warmer, so accelerating the rate of heat loss downwards to the ground or undercroft.
Rather than gut my kitchen I did discuss on here a while back, the merit of just digging a bfo rectangular hole in the large, clear floor area, insulating the bottom of the hole and sides and putting UFH in. It's probably a goer idea wise.
BUT...the existing kitchen ffl is nom +100mm than the rest of the ground floor. So it's back to gutting the kitchen and digging down. Not like I haven't done that before!
Under no circumstances should you wait until the bathroom is finished before starting this!
