ProDave Posted June 28, 2018 Posted June 28, 2018 I have a gas hob, currently set up for mains gas. I need to convert it for LPG. The supplier has just told me no such conversion kit is available. So I have to do it the hard way, work out from the existing jets what sizes the new ones need to be. So the 4 jets currently in the hob are stamped 103, 103, 115 and 72 Anyone know how to calculate what sizes I need? Or do I just take a punt and buy this kit and just try it? https://www.ebay.co.uk/itm/LPG-Gas-Jet-Set-4-Burner-Cooker-Hob-Calor-Propane-Nozzle-Conversion-Kit-NEW/222794793274?hash=item33df9ac13a:g:vh8AAOSwp7FaWkSm
Temp Posted June 29, 2018 Posted June 29, 2018 This explains what the numbers mean but i think you need to look up the numbers your appliance needs for lpg. https://www.ebay.co.uk/gds/How-to-choose-Jet-Nozzle-for-your-gas-appliance-/10000000202400690/g.html There is a post here... https://www.navitron.org.uk/forum/index.php?topic=19031.0 That says the number for lpg should be 65-70% of that for natural gas.
Temp Posted June 29, 2018 Posted June 29, 2018 Perhaps worth pointing out that if you get it wrong your hob might produce a lot of carbon monoxide. 1
joe90 Posted June 29, 2018 Posted June 29, 2018 I have just had my rangemaster converted but I have no ideas about numbers, perhaps message the Ebay seller for confirmation that the jets are for your cooker?
ProDave Posted June 29, 2018 Author Posted June 29, 2018 12 hours ago, Temp said: Perhaps worth pointing out that if you get it wrong your hob might produce a lot of carbon monoxide. You can tell a lot from the flame colour, if it burns with a yellow flame I would be worried. And there will be a CO alarm not far away
ProDave Posted June 29, 2018 Author Posted June 29, 2018 12 hours ago, Temp said: This explains what the numbers mean but i think you need to look up the numbers your appliance needs for lpg. https://www.ebay.co.uk/gds/How-to-choose-Jet-Nozzle-for-your-gas-appliance-/10000000202400690/g.html There is a post here... https://www.navitron.org.uk/forum/index.php?topic=19031.0 That says the number for lpg should be 65-70% of that for natural gas. The jets in the Polish ebay kit are in the range 65-70% so I think I will proceed and buy that.
ProDave Posted July 14, 2018 Author Posted July 14, 2018 Just to finish this off, I fitted the new jets today. Here's what I ended up with: Mains jet size LPG jet aize 103 67 103 66 115 86 72 50 I had bought a pack of 6 jets which gave me a few more options to play with. All seems to be working fine. 1 1
Temp Posted July 14, 2018 Posted July 14, 2018 Jolly good. If your hob is on cylinders I think you will be surprised how little gas a hob uses. Ours gets a lot of use and a 47kg cylinder lasts at least 18 months. 1
