Ok
I will have a concrete slab but not much depth to get pavers in .
My superior has chosen pavers that are 80mm thick - so that really helps .
At the deepest end (concrete base to finish ) I’ve got maybe 18cm . Plot slopes so going down to 12cm ?
As my ‘base’ is solid do I skip the mot1 and just do sand ?
This is above living accommodation so suds etc. not an issue
cheers
Edited by pocster
Aren’t you parking on this ..??
You may need to go with a stiff sand / cement screed that you lay direct on to as you may find just sand will shift.
? We are meant to park on it but in reality never will .
I did the driveway in my old house the conventional way and actually parked on it no issue . Perhaps different (??? ) sand for this one ???
Edited by pocster
you have a slope and not a lot of sand under that end slab at 40mm so you will need to watch for pivoting. I'd go a 6:1 sand cement mix whacked down and lay on that so it doesn't move about.
Ok
Will I still need to lay the blocks proud by say 5mm i.e will they still wacker plate down ?
Thought it was slabs..? Can't whacker a slab unless you want crazy paving... or by pavers do you mean paving blocks..?
Yeah paving blocks . 80mm deep , 100mm wide and I think maybe 400mm long . Buggers to lay I’m guessing ?
3 minutes ago, PeterW said:
Nah...!! Dead easy !!
Read this lot from end to end..... http://pavingexpert.com/blocks.htm
Oh yeah I read that before
was more worried due to lack of depth ( hence just sand ) and also the depth of 80mm - thought they might ‘wack’ down less
