Wickes have some  Setcrete Universal Floor Levelling Compound - 20kg on sale plus I get 10% discount.
I want to level a small area of floor but it requires a compound of 10mm and the stuff on sale only goes to 6mm so the question is can I just use layers to build it up?
Its over a screed floor
Ta
Yes, you can do it in 2/3 layers so long as you give it plenty time inbetween to cure.
Depending on what you are levelling onto you might want some SBR
Ta
If you lay fibre mesh on a 5 mill coat You can add another 5 mill the following day
Screwfix have Mapei Ultimate for £10 and it will go to 10mm no problem but it only does 4sqm not 5 at 3mm....
