Pip Posted April 12, 2018 Posted April 12, 2018 Hi, if anyone can help that would be great. My shower has always had a small small leak but never bothered me as was the odd drip every now and the. Recently it’s began gushing water. It was fitted 2 years back and one of the parts seemed odd then, and now it’s were the water is coming from. I’m wondering if they’ve fitted it the wrong way round, as it seems the gap would be to release water back into the shower and not out of it. I’ve added photos if any plumbers can have a look and let me know that’d be great. I’ve taken the top one off to take a photo, the gap faces outside the shower on both top and bottom. Also, the caulk is what I’ve done when trying to stop the leak, yes it’s crap haha. thanks phil
RichS Posted April 12, 2018 Posted April 12, 2018 Looks to me like these are "handed" and they have fitted the top one to the bottom and vise-versa.
Onoff Posted April 12, 2018 Posted April 12, 2018 Our resident shower guru who loves leeks will be along shortly... 1
Nickfromwales Posted April 12, 2018 Posted April 12, 2018 Simply looks like that has snapped out to me. I've never seen one like that and I've fitted a LOT of showers. I'd say it was damaged whilst fitting it, so swap the top and bottom ones over maybe, but look to see if the rise and fall cam, the white / opaque looking nylon bit with the V notches in it, is the same.
Nickfromwales Posted April 12, 2018 Posted April 12, 2018 If it's only 2 years old, see if you can buy that as a spare part.
Pip Posted April 13, 2018 Author Posted April 13, 2018 Cheers folks. I’ll check they’re the same and try swapping them nick. Should be fun as they ‘no nailsed’ it to the tiles because the tiles were apparently not taking the drill very well. Could get messy. I’ll see if there is a solution that weakens no nails glue. thanks again
Nickfromwales Posted April 13, 2018 Posted April 13, 2018 Why not make a small clear plastic upstand and use that instead ? Some stiff clear plastic from retail packaging may do it. Be prepared to buy a new shower if pulling this lot apart isn't easy from the outset. Also be prepared for the lowest tile to come away too if any moisture has got through the silicone and to the plasterboard.
