Tin Soldier Posted February 14, 2018 Posted February 14, 2018 Hi There, During my extension I need to remove the existing combi-boiler, and I am in the process of firming up prices for the proposed replacement, Grant external system boiler, Telford sealed thermal store. Now the problem is where these would ideal be located are not perfect, for where the boiler will be located. Option 1 is my preffered choice as it there its in a good location within the proposed utility room and looses the minimal of space. This is housed in a 15 year old single storey extension, probably sitting on 100mm concrete, dpc and minimal if any insulation Option 2 is similarly located but basically dead opposite the boiler. Now the problem I am facing is how to get the pipes from one to the other, if at all possible. do I come through the external wall, then strip off the plasterboard of interior walls and ceiling and run the pipes up and over to the boiler, or dig out a channel within the floor and run the pipes that way? I know the ideal location is probably just on the other side of the external wall opposite the boiler, but that's not to be as the wife will not have it there. What's my best option?
ragg987 Posted February 14, 2018 Posted February 14, 2018 I think up and over would be better? Or inside the partition wall to Option 2? Easier to attend to leaks etc, or make future changes, and also means you are not heating the slab all the time.
Nickfromwales Posted February 14, 2018 Posted February 14, 2018 Id cut a pair of channels in the floor and insulate them with some 12mm wall armorflex. ? Negligible heat to floor slab then.
Tin Soldier Posted February 14, 2018 Author Posted February 14, 2018 thanks two very different responses Ragg987, possible an option, but that partition doesn't exist at the moment and won't for a few months. it's currently my kitchen which is being split into two, Nick why cutting a channel and not up and over? - just wondering how you decide upon these things In terms of cutting channels, how deep are we talking here, and I assume the lagged pipes are cemented over?
ragg987 Posted February 14, 2018 Posted February 14, 2018 @Nickfromwales is far more qualified than me for this - mine is more an opinion and probably what I would do faced with this choice.
Tin Soldier Posted February 14, 2018 Author Posted February 14, 2018 also, do wall chasers cut concrete?
PeterW Posted February 14, 2018 Posted February 14, 2018 Stihl saw with diamond disk and it will go through the rebar etc too. Cut 3”deep and make it slightly vee shaped and cut 3 or 4 parallel slits. Take a cold chisel and smack into the cut and the centres will break out sideways.
