Hi all,
When choosing dimmable LED lighting for a bathroom, what do you normally check to avoid flickering or an inconsistent dimming range?
Is it mainly a matter of matching the dimmer to the LED driver, checking the minimum load, or choosing fittings that are specifically designed to work together?
I'm also interested in whether you've found any particular compatibility issues with bathroom downlights or mirror lighting, especially when dimming at lower levels.
Would be useful to hear what checks have worked well in practice and what you'd recommend checking before installation.
