Mulberry View Posted 8 hours ago Posted 8 hours ago My Father-in-Law has a 4kw system on the bumper tariff. Lucky him. We both bought in at the same time, but I moved house to enjoy the delights of self-building! Anyway, he's interested in adding some battery storage. Do we have anyone here that can give me some clues as to what might be involved? He still has the original Sunny Boy inverter, running flawlessly and has since connected a Solar iBoost to it for the immersion heater. He's not looking for the pinnacle of technology, more a cost-effective way to utilise the energy he's generating. He has no export meter by the way. 😉 He isn't really in a position to go EV at this stage.
JohnMo Posted 7 hours ago Posted 7 hours ago Just do AC coupled battery then leave everything else as it is, maybe bin the iBoost and let that power go to the battery instead. Plenty of offering on the market from about 2kWh and upwards 1
DamonHD Posted 4 hours ago Posted 4 hours ago If the iBoost is set correctly (I have an Eddi so have more knobs to twist to make it work) then the battery will get in first anyway. Yes, AC-coupled is the way to go. Tell/ask the FiT administrator before doing it. Exports will go to deemed if not already so.
Mulberry View Posted 4 hours ago Author Posted 4 hours ago (edited) 55 minutes ago, DamonHD said: If the iBoost is set correctly (I have an Eddi so have more knobs to twist to make it work) then the battery will get in first anyway. Yes, AC-coupled is the way to go. Tell/ask the FiT administrator before doing it. Exports will go to deemed if not already so. I think they were deemed from the start? No export meter, just a 50% payment for export Edited 3 hours ago by Mulberry View
Mulberry View Posted 3 hours ago Author Posted 3 hours ago What sort of cost is to be expected for a modest battery installed?
JohnMo Posted 3 hours ago Posted 3 hours ago https://www.solar-hub.co.uk/products/sunsynk-lifelynk-all-in-one-s-2-5kw-hybrid-inverter-2kwh-battery?srsltid=AU7gw4Wfmv0CQ7E9o5jbAHEG7L0hf7RTpp81SWdFPNikp0QgveW1Guh9 Is about £1k, have a shop about 1
Mulberry View Posted 1 hour ago Author Posted 1 hour ago (edited) 1 hour ago, JohnMo said: https://www.solar-hub.co.uk/products/sunsynk-lifelynk-all-in-one-s-2-5kw-hybrid-inverter-2kwh-battery?srsltid=AU7gw4Wfmv0CQ7E9o5jbAHEG7L0hf7RTpp81SWdFPNikp0QgveW1Guh9 Is about £1k, have a shop about Looks pretty reasonable. The description makes this sound DIY'able. Is it as easy as plugging it in and away we go? Edited 1 hour ago by Mulberry View
JohnMo Posted 1 hour ago Posted 1 hour ago Almost, plenty of videos available on YouTube. Basically 3 wires to the consumer unit and a CT clamp I believe. Add one or add a few they just daisy chain together.
Dillsue Posted 1 hour ago Posted 1 hour ago Have a read of the FIT guidance for generators so you get your set up correct. Adding an AC coupled battery between the generation meter and your consumer unit/incoming supply is likely acceptable. The guidance will also tell you if the change has to be notified to your FIt payer, which lots of things do have to be notified. If your FIL already has a 4kw system he'll need to get consent from his DNO to add any more potential export such as a battery. Don't be put off by the red tape as its all straight forward once you understand the constraints.......no one want to loose early FIT payments:) 1
