12 hours ago, Alwayslearning22 said:
it’s damaged at the top of the hose right at the connection point.
anyone help would save me a lot of worry
Is it mains pressure or gravity fed?
I had to squint to see the damage, but unfortunately it is there. The hose needs to be replaced imo as the braiding has very little mechanical purchase on that compressed ring and it’ll be very reliant on that to stop any further unravelling.
These are cheap, go get a new one ;)
Out of curiosity, are you using the wrong tools for this job?
It’s gravity fed with a booster pump.
I used one of those basin wrenches but I think I may have caught the pipe a few times with it?
Not really sure how it happened to be honest.
should I replace it straight away? Could it burst while out of the house job?
Thanks Nick
Thanks Nick
It won’t burst today or tomorrow, but change it asap. Leave this at your peril.
Is it a full bore flexi?
It’s full bore yes.
can I reuse the olive on this brass section coming from press fit? Also I’m struggling to find the right hose
49 minutes ago, Alwayslearning22 said:
It’s full bore yes.
Yea. Leave the nut and olive on. Just add some jointing compound and she’ll be mint.
Any idea what type of hose I need? The nut says it’s 21mm on it
thanks Nick
2 hours ago, Nickfromwales said:
Should be a standard large bore 22mm x 3/4” flexi:
Link
Perfect, I’ll not get it done until Monday can’t get any fittings around here until then.
Is it safe to leave the flexi as it is until then? Would you say it’s unlikely to burst. It’s actually less than a year old.
thanks Nick your a godsend on here
If the pumps not on then it’s only holding back gravity ;)  It’ll be fine.
When the pumps running it’s not under huge pressure either. Issues are largely when these are sat with full mains pressure 24/7, and then fail quite quickly (flood o’clock).
You should be good until then or longer.
Brilliant. Now I can sleep tonight. Haha
Thanks mate
