Alwayslearning22 Posted yesterday at 16:10 Posted yesterday at 16:10 Do I need to replace this flexi I think I damaged it a bit changing the tap at the very start near connector it’s hose is exposed more
Alwayslearning22 Posted yesterday at 18:10 Author Posted yesterday at 18:10 it’s damaged at the top of the hose right at the connection point. anyone help would save me a lot of worry
Nickfromwales Posted 11 hours ago Posted 11 hours ago 12 hours ago, Alwayslearning22 said: it’s damaged at the top of the hose right at the connection point. anyone help would save me a lot of worry Is it mains pressure or gravity fed? I had to squint to see the damage, but unfortunately it is there. The hose needs to be replaced imo as the braiding has very little mechanical purchase on that compressed ring and it’ll be very reliant on that to stop any further unravelling. These are cheap, go get a new one Out of curiosity, are you using the wrong tools for this job?
Alwayslearning22 Posted 10 hours ago Author Posted 10 hours ago 30 minutes ago, Nickfromwales said: Is it mains pressure or gravity fed? I had to squint to see the damage, but unfortunately it is there. The hose needs to be replaced imo as the braiding has very little mechanical purchase on that compressed ring and it’ll be very reliant on that to stop any further unravelling. These are cheap, go get a new one Out of curiosity, are you using the wrong tools for this job? It’s gravity fed with a booster pump. I used one of those basin wrenches but I think I may have caught the pipe a few times with it? Not really sure how it happened to be honest. should I replace it straight away? Could it burst while out of the house job? Thanks Nick
Nickfromwales Posted 8 hours ago Posted 8 hours ago 2 hours ago, Alwayslearning22 said: It’s gravity fed with a booster pump. I used one of those basin wrenches but I think I may have caught the pipe a few times with it? Not really sure how it happened to be honest. should I replace it straight away? Could it burst while out of the house job? Thanks Nick It won’t burst today or tomorrow, but change it asap. Leave this at your peril. Is it a full bore flexi?
Alwayslearning22 Posted 7 hours ago Author Posted 7 hours ago 55 minutes ago, Nickfromwales said: It won’t burst today or tomorrow, but change it asap. Leave this at your peril. Is it a full bore flexi? It’s full bore yes. can I reuse the olive on this brass section coming from press fit? Also I’m struggling to find the right hose
Nickfromwales Posted 6 hours ago Posted 6 hours ago 49 minutes ago, Alwayslearning22 said: It’s full bore yes. can I reuse the olive on this brass section coming from press fit? Also I’m struggling to find the right hose Yea. Leave the nut and olive on. Just add some jointing compound and she’ll be mint. 1
Alwayslearning22 Posted 6 hours ago Author Posted 6 hours ago 20 minutes ago, Nickfromwales said: Yea. Leave the nut and olive on. Just add some jointing compound and she’ll be mint. Any idea what type of hose I need? The nut says it’s 21mm on it thanks Nick
Nickfromwales Posted 3 hours ago Posted 3 hours ago 2 hours ago, Alwayslearning22 said: Any idea what type of hose I need? The nut says it’s 21mm on it thanks Nick Should be a standard large bore 22mm x 3/4” flexi: Link 1
Gone West Posted 3 hours ago Posted 3 hours ago 26 minutes ago, Nickfromwales said: Should be a standard large bore 22mm x 3/4” flexi: Are corrugated stainless steel flexi connectors a better type, or are there any downsides? https://ridgelinetubes.com/flexis/
Nickfromwales Posted 1 hour ago Posted 1 hour ago 1 hour ago, Gone West said: Are corrugated stainless steel flexi connectors a better type, or are there any downsides? https://ridgelinetubes.com/flexis/ Never used them before tbh, so may give them a whirl. Seems to make sense to upgrade if these are kosher.
Alwayslearning22 Posted 1 hour ago Author Posted 1 hour ago 2 hours ago, Nickfromwales said: Should be a standard large bore 22mm x 3/4” flexi: Link Perfect, I’ll not get it done until Monday can’t get any fittings around here until then. Is it safe to leave the flexi as it is until then? Would you say it’s unlikely to burst. It’s actually less than a year old. thanks Nick your a godsend on here
Nickfromwales Posted 1 hour ago Posted 1 hour ago 18 minutes ago, Alwayslearning22 said: Perfect, I’ll not get it done until Monday can’t get any fittings around here until then. Is it safe to leave the flexi as it is until then? Would you say it’s unlikely to burst. It’s actually less than a year old. thanks Nick your a godsend on here If the pumps not on then it’s only holding back gravity It’ll be fine. When the pumps running it’s not under huge pressure either. Issues are largely when these are sat with full mains pressure 24/7, and then fail quite quickly (flood o’clock). You should be good until then or longer.
Alwayslearning22 Posted 1 hour ago Author Posted 1 hour ago 12 minutes ago, Nickfromwales said: If the pumps not on then it’s only holding back gravity It’ll be fine. When the pumps running it’s not under huge pressure either. Issues are largely when these are sat with full mains pressure 24/7, and then fail quite quickly (flood o’clock). You should be good until then or longer. Brilliant. Now I can sleep tonight. Haha Thanks mate
