markharro Posted September 22 Posted September 22 We dont yet have our outlet plumbed in to the drain but rather it is dropping into a bucket below the MVHR unit and empty the bucket as and when needed. Because of this its easy to monitor the water coming out - the confusing thing is that the bucket has been dry for about the last 6 months! Is this normal over the warmer months? thanks
JohnMo Posted September 22 Posted September 22 Yes pretty normal, we don't make much condensation in summer. It's warm or warm damp air in winter from house being cooled across the heat exchanger, releasing water which goes to drain.
Jolo Posted September 22 Posted September 22 Same here. Since I installed our current MVHR unit in March or April (can't remember exactly!) it dribbled for a few weeks, then it's been dry ever since. I also have it dropping into a bucket, for the same reason! Must buy that concrete hole drill...
Nickfromwales Posted September 22 Posted September 22 Defo not an issue. Some AC units and fan coils can be set to not go to a low enough temp to produce condensation, to mitigate needing a waste pipe or pumped solutions. All good
FarmerN Posted September 22 Posted September 22 5 hours ago, markharro said: We dont yet have our outlet plumbed in to the drain but rather it is dropping into a bucket below the MVHR unit Do you have a self sealing waste( Dry Trap ) valve fitted, or is it literally straight into a bucket? If not it may be able to draw air back into its self. Not sure what this would do but probably not ideal. My Zehnder could draw air in that way, making gurgling noises once there was condensation.
Conor Posted September 23 Posted September 23 On 22/09/2026 at 13:50, markharro said: We dont yet have our outlet plumbed in to the drain but rather it is dropping into a bucket below the MVHR unit and empty the bucket as and when needed. Because of this its easy to monitor the water coming out - the confusing thing is that the bucket has been dry for about the last 6 months! Is this normal over the warmer months? thanks I've had a bucket under our mbhr for four years now. It only produces condensate when it's cold and dry outside. Dry most of the time. Maybe makes 10l in a year.
