Makeitstop Posted 4 hours ago Posted 4 hours ago (edited) Part of a job my daughter and son in law have underway is posing an either or type discussion..... This is..... The rear of the property is being extended and will be approx 70..ish sq metres once complete. The aspect is pretty much dead west facing, so plenty of sun. The glazed elements of this rear section are.... Slider of approx 4 metres by 2.4 metres Single pane t&t window of approx 1.8 metres high by a metre wide. Velux Rooflight of approx 2.5 metres long by 1 metre wide, split into two sections, one half fixed and other half electrically operated opener, fitted into small section of flatroof. Now, given the fact that this is west facing, which means a fair solar gain, would people choose 2g with solar glass, or 3g with standard glass? I ask, as the prices come in about the same for each. To me anyhow, this is how they stack up.... Benefits of 2g and solar glass 1) less solar gain. Thats about it from what I can come up with. Benefits of 3g std glass 1) Less noise during heavy rain 2) Better ability to trap in warm air that rises within the room during colder weather 3) Lower risk of condensation Given the fact that this rooflight has the ability to open during hot summer weather too, which allows warm air out, how much benefit does solar glass provide in reality? Both will have some affect on light transmission I know, but I've not looked into what the "actual" diff is. At the same cost, what would you pick and why? Am I missing anything obvious here? Edited 4 hours ago by Makeitstop
Sparrowhawk Posted 3 hours ago Posted 3 hours ago My understanding of solar control glass is that up close you can see the coating on it. And that coating also reduces the light transmittance to around 70%, similar to triple glazing. So if the slider can take the weight then I'd go 3g
Jonny Posted 3 hours ago Posted 3 hours ago Also, with solar glazing, you are losing the benefit of “free” solar heating in the winter months. 1
