Hi, Would like some advice on how best to seal up this crack in a corrugated asbestod roof which is letting in water to the area behind. The surface is a stable paint finish. TIA
Not tried it on asbestos but Denso tape worked brilliant on some corrugated sheets that had rust holes
Edited by Beau
Denso tape does work well on Asbestos cement sheets, brush away loose crud and rub it down well to get hold.
But wear mask gloves etc to protect yourself - if it is indeed asbestos.
